Trailer Hitch/Receiver - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 03-01-2012, 05:44 PM Thread Starter
MeSeaHunt's Avatar
Default Trailer Hitch/Receiver
Has anyone installed a receiver on their Vision? If so which brand did you go with and do you have any pics & any addl input/comments on the install process?? Thanks
Semper-Fi
2011 Pearl White Vision (air-brush makeover in the works)
2011 ION Trailer
2009 Red R1200 BMW GS Adventure
2008 105th Anniversary HD Ultra Classic
MeSeaHunt is offline
post #2 of 15 (permalink) Old 03-01-2012, 05:52 PM
i also would like to find one for my 2012 xct i have found some for older bikes but no one has one for a 2012,
[SIGPIC]:ltr:[/SIGPIC]
schlep is offline
post #3 of 15 (permalink) Old 03-02-2012, 07:48 AM
Buster's Avatar
Bushtec and Cyclemate make hitches for the Vision.
I installed mine in about 3 hrs. and you do not have to remove the rear wheel. The hardest part for me was hooking up the electrical. A lot of body panels had to come off the rear to get to the wires I needed. I needed a 5 wire connector because my trailer had seperate turn signals. Had to call a friend over to help. Without his help I could have fried the wiring trying to make 4 wires work with 5. It took longer to do the wiring than installing the hitch.
Buster
2008 Vision Tour
Buster is offline
post #4 of 15 (permalink) Old 03-02-2012, 09:36 AM Thread Starter
MeSeaHunt's Avatar
thanks for the input Buster....
Semper-Fi
2011 ION Trailer
post #5 of 15 (permalink) Old 03-03-2012, 09:04 AM
lstayner's Avatar
Hitchdoc. It is a very straight forward install. I pull an Uni-Go trailer.
ATGATT because walking away in disgust is better than riding away in an ambulance.
Never get to busy making a living that you forget to make a life.
Larry
2011 Pearl White Vision 88,000 smiles
lstayner is offline
post #6 of 15 (permalink) Old 03-03-2012, 04:18 PM Thread Starter
MeSeaHunt's Avatar
Larry, is it a vertical receiver? No problems w/the wiring? Any pics? Thanks
Semper-Fi
2011 ION Trailer
post #7 of 15 (permalink) Old 03-04-2012, 10:36 AM
I installed a Hitch Doc on my 2011 XC, easy enough. Only problem I found a few of the supplied bolts were short, called them and they offered to send replacements, I had already bought some new ones. They stated the proper ones would be sent with future hitch packages.
Did not have to remove the tire, just the bags and the seat.
You would have to do some checking, I doubt that there is any difference between a 2011 XC and a 2012 XCT as far as mounting a hitch. This is my third Hitch Doc, never a problem with the hitch.
Good luck.
2008 Vision Black gone 2005 TC- Sold
1963 Triumph Bonneville,not sure on color-be awhile
1983 XS 650 Custom Midnight Gold
2007 Ural Patrol Black-Sold
2011 Cross Country White and Silver
2012 Cross Country Red and Silver--Hers
A bunch of other bikes over the years, mostly all good
Life is short, eat dessert first, simple enough.
N/E Georgia and my garage
Shuffles is offline
post #8 of 15 (permalink) Old 03-08-2012, 04:42 PM Thread Starter
MeSeaHunt's Avatar
thank you everyone for your input, I have decided to go w/the hitchdoc, hopefully it will not show in the rear when the ball is removed? Had to order the harness from open road outfitters so will have to wait to see how his install instructions work out?
Semper-Fi
2011 ION Trailer
post #9 of 15 (permalink) Old 03-09-2012, 07:48 AM
The receiver will not show to any extent when it is installed. I got my wiring harness from electricalconnection.com and it was easy to wire in and the instructions were pretty clear. Just take your time and use a tester to be sure before yu finish your connections. Remember to turn the switch on the right handlebar on when testing your work. Don't ask.......
Shuffles is offline
post #10 of 15 (permalink) Old 03-09-2012, 08:40 AM
ronfox's Avatar
any pics from yall!!
SUPPORT YOUR LOCAL ABATE !!
KNIGHTS OF SOLOMON MC
HARRIS COUNTY, GA,
custom 1999 bobber
2012 cross country tour
sunset red
D&D slip on
16 inch ness apes
performance up grade ( cams, )
painted red inside fairin to match
(mods to come )
Its not really what you ride, but that you ride!
ronfox is offline
