Kickstand - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 11-29-2012, 08:03 AM Thread Starter
mikebna's Avatar
Default Kickstand
I'm having a hard time with the bike when I place it on the kickstand. It really seems that it wants to tip over away from the kickstand even when I crank the wheel all the way into it. I have never had a bike stand up this straight when placed on the kickstand and it will tip to the other side really easy. Also when parked on a slight grade it's even worse and will actually slide and start to tip over really easy.
I wonder if it has anything to do with the suspension being a little lower than a standard Vision? It's a 2013 Ness Vision.
Any suggestions on what to do to make it lean a bit more? And how to keep it from sliding on the kickstand with even the slightest grade? Thanks-
mikebna is offline
post #2 of 19 (permalink) Old 11-29-2012, 08:22 AM
of course if you lower the bike with the same kickstand it will stand up straighter. i would hope on a ness bike if it was factory lowered they would put a shorter kickstand on it though. does it have the rubber on the bottom of the foot?
now , 2011 crossroads and 05 sportster bobber in the making
in order of ownership, sears compact scooter, honda 305 scrambler, honda 160 dream , triumph 500 trophy trail, honda cb450, sportster, honda f750, 2nd sportster, harley flh, harley super glide, 3rd sportster, bmw k1000, harley low rider, 2nd harley super glide, harley heratage, harley road king, bmw r1150rt,
thats just the street bikes!
ridealittle is offline
post #3 of 19 (permalink) Old 11-29-2012, 08:23 AM
Tims_04V92TC's Avatar
I think you might have something about the Ness maybe being lower. I have not had any issues on the lean but have notice it does want to slip forward a bit easier than my TC.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #4 of 19 (permalink) Old 11-29-2012, 08:23 AM
Easy fix... couple of vendors sell a shortened kickstand for lowered bikes..... HMD is one, and I know there are others. As for sliding forward, leave the bike in 1st gear whenever you park.
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
post #5 of 19 (permalink) Old 11-29-2012, 11:36 AM
Go to dealer and measure the length of a vision kickstand thats not a ness one. You might have the wrong kickstand on your bike.
If not maybe your dealer can put your kick stand is his press and bend it.
Or HMD sell one measure yours and ask them what length theres is so you know if it will change any thing.
http://www.hmd520.com/category/Suspension-2
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton
No Polaris ever again
Don't Text and Drive
post #6 of 19 (permalink) Old 11-29-2012, 01:11 PM
if you're handy you can cut it shorter and re-weld it or bend it, i don't know if it could be bent out enough without sticking out though. personally i would try bending it out first, cutting it shorter and re-welding if that won't work, but i'm just cheap and will try anything before spending money.
post #7 of 19 (permalink) Old 11-30-2012, 07:32 AM Thread Starter
mikebna's Avatar
Thanks for the info, I did find that as a possible solution when I searched here.
I will, thanks for the info. You would think they would catch that when they put it together, I'm sure that I'm not the only one that may have this problem unless they forgot.
Yes mine does even on slight grades, now I know why my Harley's jiffey stand was so long and would extend out further.
Yes the rubber piece is still on it, I was thinking about removing it to help it lean a bit more.
2013 Arlen Ness Vision
L1 Exhaust, PC5, Top Ness Air Filter, Vision Fog Lights, Lighted Victory Trunk Emblem, Highway Pegs, Lighted Victory Heritage Badges, Drivers Backrest, Passenger Arm Rests, Lots of extra chrome pieces added...
mikebna is offline
post #8 of 19 (permalink) Old 11-30-2012, 11:04 AM
Get your dealer to bend it. They more then likely have a ten ton press that will bend it just fine. You will not need much of a bend. Thats what I did mine.
Putting heat to it will be fine but in a years time it will give out on you.
Still think you should measure and compair.
No Hillary Clinton
post #9 of 19 (permalink) Old 12-05-2012, 01:40 PM Thread Starter
mikebna's Avatar
Ok I finally made it in today to the dealer and had the service manager measure mine and another regular Vision and they both have the same length. He said he was going to order a shorter one at no charge. I hope they come through cause I do not want to pay $205 for a shorter one.
mikebna is offline
post #10 of 19 (permalink) Old 12-09-2012, 07:25 PM
TheMike's Avatar
This is all very interesting. I thought mine stood up too much too but just attributed it to the make. I'm gonna research this as well.
According to the parts schematic (http://parts.polarisind.com/Browse/Browse.asp) there are NOT any differences between the kick stands on the Visions. Ness or not.
2012 #20 NESS Vision DARKSIDE BABY!
Stage 1 w/D&D pipes + lots of Victory add ons. PC-V w/AT, Lloyd's intake, filter, ATS, & Variable Clutch.
2013 Bushtec Entourage in matching Ness color and graphics - See the PAINTED TO MATCH process
Wife rides a 2016 Gunner
LONGMONT COLORADO
TheMike is offline
