vision longer shift linkage - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 01-25-2011, 04:49 AM Thread Starter
firetruck41's Avatar
Cool vision longer shift linkage
I am amazed how little dealers know about the vision. I wanted to move the shift lever forward, so i call two dealers, they did not know what the hell i was talking about, i'll call you back, crap'
does anyone know the part number or shift rod length, for the relocation?
firetruck41 is offline
post #2 of 5 (permalink) Old 01-25-2011, 07:55 AM
Buster's Avatar
The shifter is adjusted in a center position from the factory.
It is adjustable fore and aft about 2".
There are 2 bolts that hold the shifter to the running board.
Remove the bolts, slide to the position you want, install the
bolts and adjust the linkage.
You can also adjust the brake in the same way.
Buster is offline
post #3 of 5 (permalink) Old 01-25-2011, 08:53 AM Thread Starter
Default shift linkage
i already know all of this. i have adjusted the brake lever already. the book says if you adjust the shift lever to the forward position, you will need the longer shift rod.
post #4 of 5 (permalink) Old 01-26-2011, 05:27 PM
Not true. I moved it forward on my 08 and it worked fine.
team5150 is offline
post #5 of 5 (permalink) Old 01-26-2011, 07:38 PM
sgtfixit's Avatar
Default moving shift lever
I'll chime in...I did this on my 11 XC...after moving the shift lever to the forward position, the rod would not reach unless the lever was laying almost on the floor board. I released the pinch bolt on the shifter arm where it attaches at the case. pulled it straight off, then indexed it 2 or 3 teeth clockwise. the rod can then be re-attached. Have no problems with this configuration so far. Hope this will work for you...just dont forget to tighten down the pinch bolt on the shift arm and the lock nuts on the rod. I used locktite on all bolts to ensure no loosening I didnt want!
MSgt Ret. Security Forces USAF/Lompoc, CA
2011 Victory Cross Country (Imp Blue)
-Mods-Vic Military Salute Wedge Covers/Madstad with stock shield/Floor Board Hwy Pegs/2012 Hard Lowers/Hard Bag Bars/adj. pass. foot rests/+2 SRVT Pull Back Bars/Mirror extenders/LED driving lights/WOLO horn/RicZ laid down plate bracket/Kuryakyn Brake Pedal/Signal Dynamics headlight modulator/Custom Dynamics Brake light Strobe/LED rear plate/1/4 turn throttle ring/Lloydz timing wheel +4
sgtfixit is offline
