did my first oil change - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 02-19-2011, 08:37 AM Thread Starter
firetruck41's Avatar
Wink did my first oil change
very little metal in oil, that i could see. belt gauge says still in spec(34mm)
there just can't be a better road bike than this.
2011 vision tour, Sold. looking for XC
stage1 exhaust.
Ceebaileys 20'' tint screen
backrest.
garmin 220 zumo .
firetruck41 is offline
post #2 of 8 (permalink) Old 02-19-2011, 09:05 AM
Bungln's Avatar
see if you can find a magnetic oil drain plug too. always worth the $10-15 IMHO. and you're right, one fine motorcycle.
if the house is a rockin', don't bother knockin'
2004 Vegas.
swept pipes
S&S airbox
OD pulley
lots of chrome goodies...
70K trouble free miles as of 4/1/11
cheers
Bungln is offline
post #3 of 8 (permalink) Old 02-19-2011, 12:05 PM
CrossRoads's Avatar
Doing your own oil change is not only cost effective, but therapy for your soul.
About the magnetic plug, while I understand and appreciate its purpose, I always wonder what percentage of the particles that come loose are actually magnetic. Especially in the case of a Victory engine.
Does anybody have them in a low profile, similar to the OEM plug? I cannot stand the idea of a plug sticking down lower than the factory one - even though the odds are probably better to win the lottery than have a rock hit the drain plug and break it off, I still wonder about that aspect. I would love a magnetic drain plug that's comparable in size with the stock drain plug.
CrossRoads is offline
post #4 of 8 (permalink) Old 02-19-2011, 12:52 PM
Magnetic plug is cool idea...the permanent oil filters also have a rare earth magnet in them for pre-filtering as well....the mag plugs are not that big as to cause a problem...Have one on my Vic....
Northern NY...2010 Vegas, S&S Performance Intake, PCV with Auto tume module , Bassani 2 into 1 Short pipes, Kewl metal accessories, Cycle-ops accessories...:crzy:
Paul M is offline
post #5 of 8 (permalink) Old 02-19-2011, 01:18 PM
There is a magnet that is strapped around the oil filter. I don't anything more about it, only saw a mention of it in a magazine.
2010 Midnight Cherry XR. Lloydz AF, ATS, VFCIII, IAV, and T-6 and locally repacked pipes = big smiles.
+ For the best and cheapest license plate laydown bracket, click this:http://www.victoryforums.com/showthr...highlight=ricz
+For easier fill ups, get the Bellowz Buddy, click here: http://www.victoryforums.com/37-gene...nnovation.html
RICZ is online now
post #6 of 8 (permalink) Old 02-19-2011, 06:12 PM Thread Starter
Wink first oil change
I think it's futile to add the magnet after the first oil change. the engine parts are pretty much worn in.
stage1 exhaust.
backrest.
garmin 220 zumo .
post #7 of 8 (permalink) Old 02-19-2011, 10:39 PM
New Member
I hear that! Plus you know it's done right! I have always used a magnetic drain plug in my machines. A engines ferrous wear particles will keep sloughing off through the live of an engine (rings and cylinder wall). I have had good luck with Gold Plugs. www.goldplug.com
spurline is offline
post #8 of 8 (permalink) Old 02-23-2011, 04:28 PM Thread Starter
Wink
well i put an additional 350 miles on this week end. wife was aboard. that made weight around 400lbs with no luggage. the belt finally loosen up. needed to adjust. i settled on 28mm. now she's good to go.
stage1 exhaust.
backrest.
garmin 220 zumo .
