from full synthetic back to Victory oil ??? - Victory Forums - Victory Motorcycle Forum
post #1 of 39 (permalink) Old 10-25-2012, 10:13 AM Thread Starter
jaysonL's Avatar
Default from full synthetic back to Victory oil ???
Would that cause any problems ? I know at one time, that it was said that once you switched to full synthetic you shouldn't switch back to conventional. I remember someone telling me it was hard on seals and various delicate internals. But I know today there are numerous syn/blends on the market. So, has anyone done this, or have any real knowledge of whether it may be a bad idea ?
2009 Kingpin 8 Ball
Freedom Performance sharp curve radius pipes
Cross Roads bags mounted with Witchdoctor brackets
Kingpin tour tins
jaysonL is offline
post #2 of 39 (permalink) Old 10-25-2012, 10:42 AM
half_crazy's Avatar
Most everything you have heard about synthetic oil is a myth. Synthetic is perfectly compatible with petroleum oil.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #3 of 39 (permalink) Old 10-25-2012, 10:59 AM
OkieHoss's Avatar
No problem...
2013 black XCT.
OkieHoss is offline
post #4 of 39 (permalink) Old 10-25-2012, 11:17 AM
Pckrfan's Avatar
I thought Victory 10-40 was a semi-syn anyway.....no?
2013 AG-XC:
Debadged, Gustafsson +2 Euro Flip windshield
Ma Vic (Black Tri-Ovals/S1 Package, pull backs, HID,
heated seat, bag bars, shorty antennae)
Ness (derby covers, Rad III mirrors)
Avon heated grips, Wolo Bad Boy air horn
RICZ's LD PL8 bracket and lotsa blacked out stuff
GOODY'S fork mounted lowers (3M'd)
Bag graphics & inner fairing, Bad Boys Design Peoria, AZ. Sena & XM in the saddlebag
Artificial intelligence is absolutely 100% NO MATCH...............for natural stupidity!
Pckrfan is offline
post #5 of 39 (permalink) Old 10-25-2012, 11:24 AM
lunaticrider's Avatar
This is true...
Sent from Hell....
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #6 of 39 (permalink) Old 10-25-2012, 11:57 AM
Guys stick with one oil. Do Not keep switching.
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton vote.
No Tapatalk.
Don't Text and Drive ​​
post #7 of 39 (permalink) Old 10-26-2012, 08:29 AM
handyhoward's Avatar
Your girlfriend might care what lubricates her, but rest assured your engine does not... as long as it is lubricated.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #8 of 39 (permalink) Old 10-26-2012, 08:41 AM
slickvic's Avatar
Victory oil is a syn-blend but I have to ask why you are switching back? What are you switching back from?
slickvic is offline
post #9 of 39 (permalink) Old 11-04-2012, 11:59 AM
Pop
You are describing a classier girl than I am acquainted with.
As far as the engine goes, I tend to agree. Peeps get way too anal about the earl in their pearl. Recommended viscosity and detergent rating are both worth maintaining since oil pumps interact with varying types to different degrees of efficiency. Will using a different viscosity or detergent rating motor oil lunch the mill? Not in the short term for sure. Any motor oil beats no motor oil.
The flip side is that if you want to minimize variables then using the same product over and over is in keeping with that effort.
What I don't know is what effect various non specified motor oils will have on Victory clutches. I'm just too green with this brand and looking forward to the learning curve in the primary. As opposed to the engine which is metal, polymers and some standard fibrous gasket compounds, all common materials and all forgiving of motor oil flavors, I don't know what effect non specified oils will have on the fibrous components of the clutch. I know what I can get away with in a Harley primary but the requirements of the Victory clutch are not identical. Although the basic execution is the same the requirements for viscosity, the effect of oil mixture on the fibres under varying temperature and pressure conditions and who knows what else may make using a specified product necessary to clutch performance and/or longevity.
Until I have put my grubby little hands all over the Victory clutch I'm inclined to be particular with what I coat it with.
Pop is offline
post #10 of 39 (permalink) Old 12-09-2012, 12:00 AM
saddlebag's Avatar
Millions of single oil, wet clutches in bikes outside the Harley and Ducati lines.
Simple answer is don't use oils specifying "friction modifiers." Outside of those, I've use numerous cheap auto oils over the years and never had a problem.
Dry clutches SUCK. They are easy enough to change, but they burn plates so quickly and easily and they have a tendency to moan and grab and slip, there is just no reason...save that Duc folk like loud clutches to save lives...
http://www.victoryforums.com/signaturepics/sigpic6903_1.gif
2011 Cross Roads
saddlebag is offline
