New Parts and Dyno - Victory Forums - Victory Motorcycle Forum
post #1 of 70 (permalink) Old 06-05-2012, 05:23 PM Thread Starter
New Parts and Dyno
So I decided I needed some new items and more power from my XR. I ordered the Freedom Performance Duals and a PCV. I did a baseline dyno run for power/tq and AF. 86hp, 103 TQ with the Stage 1 ECU, strip removed, Vic air filter and Chesapeake Cycles aftermarket slip on exhaust. They have them made by someone with a larger exhaust outlet ( 2 inch versus 1 1/2). The AF ratio was lean at idle, lean further between 2500 and 4000 and good above 4000 and between 1500 to 2500. Cruising RPM was not smooth at all so the addition of the aftermarket controller is much needed for better power and all around riding. The pipes will be here in about 2 weeks so stay tuned!
WilCon76 is offline
post #2 of 70 (permalink) Old 06-05-2012, 06:37 PM
Hope it works out the way you want. Can't wait to see the difference.
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
post #3 of 70 (permalink) Old 06-11-2012, 05:12 PM Thread Starter
First part arrived today. Making a slight change, I ordered the Auto Tune today as well. Pipes have another week before they ship. Will still get a follow up run on the dyno for a power comparison and to see how effective the auto tune is working.
WilCon76 is offline
post #4 of 70 (permalink) Old 06-15-2012, 04:53 PM Thread Starter
Waiting on pipes. PCV installed, with stock stage 1 map ran better and was much cooler at a stop. Auto Tune installed this evening. Will be riding tomorrow so will follow up with more info.
WilCon76 is offline
post #5 of 70 (permalink) Old 06-16-2012, 07:11 PM Thread Starter
First long ride today. Auto Tune adjusted both tables some, really nice improvement overall. I have to say that it was a pleasant ride and I was definitely satisfied with the set up. Can't wait for the pipes so I can see the end results.
WilCon76 is offline
post #6 of 70 (permalink) Old 06-16-2012, 07:57 PM
sixshooter_45's Avatar
Hope ya get great results.
sixshooter_45 is offline
post #7 of 70 (permalink) Old 06-16-2012, 08:38 PM Thread Starter
I figure this will give people an idea of what they can get and should expect. Another vic rider got the same exact same numbers as I did with the same Stage 1 setup and the Chesapeake Cycles slip ons.
WilCon76 is offline
post #8 of 70 (permalink) Old 06-16-2012, 09:37 PM
The nice thing about getting the fuel controller though; is you can swap cams at some point and not need to then get the fuel controller and you will have a real feel of the difference once you do.
The Stage 1 flash doesn't quite cut it for performance cams. I wish it did. It would sure make life much easier if that's as far as one goes with the motor upgrades.
I almost feel sorry for those who can afford to get their brand new X bike with cams, full Stage 1, fuel controller and a good performance exhaust system like D&D's or others before they actually ride it. Almost.
It is nice to feel those performance upgrade in increments so they are more appreciated though...
I'm not familiar with the Chesapeake mufflers but I hope they work well for you.
post #9 of 70 (permalink) Old 06-17-2012, 01:33 AM
Garion12's Avatar
I'f following your posts intently as I too am thinking about the Freedom exhaust. It looked like the Bassani 2-1 wasn't that much of an improvement over slip ons using the stock headers.
2010 Cross Roads
Lloydz Air Filter
Lloydz Slip on Exhaust
Lloydz Timing Wheel 8*
LLoydz VM1-HPT Cams
Lloydz reflesh 6500 rpm
Dyno tuned by KMC 123 hp 121 tq
Garion12 is offline
post #10 of 70 (permalink) Old 06-17-2012, 10:04 AM Thread Starter
The Chesapeake Cycles exhaust looks a lot the RPW slip ons. They won't say who makes them but they are definitely not the Stage 1 Victory pieces.
Cams may be in the future as we see how the pipes perform. I came off of a Yamaha Raider so there was a drop off in power that is hard to stomach sometimes. Just pipes and the Cobra tuner made 98hp and 120ft/lbs out of the 113.
WilCon76 is offline
