Fuel / gas gauge inaccuracy - Page 14 - Victory Forums - Victory Motorcycle Forum
post #131 of 158 (permalink) Old 01-07-2013, 11:38 AM
The 106" engine is pretty tight when new. It'll take at least 1K miles and then some before it begins to loosen and deliver more power and mpg. During break-in, continually vary your speed and RPMs, with short bursts past 3500 rpm when in a lower gear. Keeping revs too low too long will never seat the rings. As soon as your bike left the assembly line, the throttle got twisted way down. It may still be tight, but it ain't no virgin.
2010 Midnight Cherry XR. Lloydz AF, ATS, VFCIII, IAV, and T-6 and locally repacked pipes = big smiles.
+ For the best and cheapest license plate laydown bracket, click this:http://www.victoryforums.com/showthr...highlight=ricz
+For easier fill ups, get the Bellowz Buddy, click here: http://www.victoryforums.com/37-gene...nnovation.html
RICZ is online now
post #132 of 158 (permalink) Old 01-07-2013, 09:21 PM
Originally Posted by arkiebiker View Post
OR...you have a 2013 and it's not broke in yet. How many miles do you have on the bike...and yes, THIS WILL MAKE DIFFERENCE!!
2500-3000mi just seems to get progressively worse.
2013 Cross Country!
Sunset Red blacked out!
Not a lick of chrome
Traded in and traded up!
2003 Vegas -Traded-
Autoboticus is offline
post #133 of 158 (permalink) Old 01-07-2013, 09:44 PM
arkiebiker's Avatar
Something is wrong then...you should be around 40mpg by now.
Searcy, AR
Blytheville, AR (Hometown and the BEST BBQ Sandwiches in the world)
Arkansas Bikers Website
http://www.arkansasbiker.net
Garmin Zumo GPS Forums
http://www.zumoforums.com
arkiebiker is offline
post #134 of 158 (permalink) Old 01-07-2013, 09:45 PM
Greaaaat....
2013 Cross Country!
2003 Vegas -Traded-
post #135 of 158 (permalink) Old 01-07-2013, 10:07 PM
Originally Posted by Autoboticus View Post
Greaaaat....
If you are getting very low MPG maybe you should see the dealer. That is what a warranty is for.
orbiker is offline
post #136 of 158 (permalink) Old 01-08-2013, 01:49 AM
CrossRoads's Avatar
4.5 gal 115 mi on the trip 25.5 mpg??? Is something wrong with my XC?
Was this trip in stop and go traffic, around town? Or was it cruising on the highway? Even with a lot of other variables kept constant (riding style, weather, road conditions, etc.) I can get a 10 mpg difference from doing short little rides around town on one tank, and doing some extended freeway cruising on another tank.
25mpg is low, but you're not telling us the whole story.
CrossRoads is offline
post #137 of 158 (permalink) Old 01-08-2013, 02:01 AM
Mixture of city some days, then freeway others. I have the option of either when going to work. It's about 15 miles round trip. Usually leave in the mornings around 8-8:30am and the temp varies right now from 30-40 degrees. And when I come home at around 7 it's around 50 or so out. Pretty consistent in my riding. Keep it around 2500-3000 rpm I don't really step on the gas unless necessary.
2013 Cross Country!
2003 Vegas -Traded-
post #138 of 158 (permalink) Old 01-08-2013, 02:16 AM
TN Rider's Avatar
Send a message via Skype™ to TN Rider
Originally Posted by RICZ View Post
Tell me more about that Pelican case - what model, etc.
Yes , I know it's off-topic...It's a Pelican 1440. I think I may try to get one size larger of this style though. It's the exact same width as the XC luggage rack but the rack is still an inch or two deeper than the case. It worked really well on the trip down from Nashville to Palatka, FL. With it strapped down with ratchet straps through the side handles, I can still open the top to get into it.
2011 Cross Country Ness Edition #175
Stage 1 Flash
VM1-DR cams
PC-V Controller
Underdrive pulley
Lloydz High Flow Air Filter
Big Gonzo mufflers
iPod adapter
Hidden antenna
Polk MM6501UM w/ RF PBR300x2 amp up front
JL M10IB5-SG-TB sub w/ RF M750-1D amp in the saddlebag
Madstad brackets & Dark Smoke Shield
LED Headlight
Rider Backrest
Passenger Backrest w/ Luggage Rack
Arlen Ness Retro Floorboards
Chromed Passenger Floorboards
2001 Suzuki Volusia (traded-in)- My first bike
TN Rider is offline
post #139 of 158 (permalink) Old 01-08-2013, 02:55 PM
CrossRoads's Avatar
From what you're describing, you should not get lower than 33-35 mpg. Someone else had a similar issue, and posted about it about a year or two ago. Might be worth searching the forum for it - I don't remember what their resolution was.
I would suggest seeing your dealer (hopefully you have a competent mechanic).
post #140 of 158 (permalink) Old 01-08-2013, 03:14 PM
Have you checked the simple stuff?? Brakes not dragging. Proper tire pressure?
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
