Fuel / gas gauge inaccuracy - Page 9 - Victory Forums - Victory Motorcycle Forum
post #81 of 158 (permalink) Old 11-19-2012, 04:57 PM
BeoBob's Avatar
My 2012 Cross Country has all the same issues…* gas gauge moves real slow at first and then moves real fast for the last quarter tank, the idiot light comes on with about 2 gallons left in the tank (aprox. 80 miles), and the displayed MPG (average 46.7 MPG) is a bit optimistic.* I have gotten to know my bike and just deal with it.* A full tank will outlast my butt, and anyone else’s tank for that matter.* I just fill up when it’s convenient or soon after the idiot light comes on.* I don’t even watch the miles any more.
2013 Cross Country Tour: Custom paint, stage 1 exhaust, Lloydz Hi-Flow air filter, cams (HOH-VM1-DR), timing gear (HOH-PTS), Power Commander V, Auto Tune module, Gustafson flip shield, OEM passenger backrest with Cycle Ops luggage rack, Vic HID, heel shifter, Rockford amp, Infinity speakers all around.
2011 Cross Country: Burnt and Traded
BeoBob is offline
post #82 of 158 (permalink) Old 11-19-2012, 05:02 PM
BeoBob's Avatar
That being said... it would be nice if all these things were accurate. Can't imagine what would happen if I designed something as inaccurate as this thing.
BeoBob is offline
post #83 of 158 (permalink) Old 12-14-2012, 03:11 PM
Sergio_Victory_SDL's Avatar
I read where a guy had the same problem and his dealer told him that victory says there is a bad resistor in the sending unit.
Hope you all come back here and read this
and where exactly did you read this?
Sergio Olvera
Parts Manager
Victory Motorycles of Scottsdale
8420 E Butherus Drive
Scottsdale, Az 85260
Sergio@Victorysdl.com
Phone: 480-607-7070
Fax: 480-607-6970
www.victorysdl.com
Sergio_Victory_SDL is offline
post #84 of 158 (permalink) Old 12-14-2012, 03:21 PM
They say there is a bad resistor in the sending unit and Vic is aware of it go to your dealer
who is they?
Sergio Olvera
Parts Manager
Phone: 480-607-7070
Fax: 480-607-6970
www.victorysdl.com
post #85 of 158 (permalink) Old 12-14-2012, 06:05 PM
I too would like to find out what the fix is for this. My Road King's fuel gauge is always right on. There is no reason the XCT's gauge can't work correctly.
When I can go almost a 100 more miles after the low fuel light come on, that's just not right.
orbiker is offline
post #86 of 158 (permalink) Old 12-15-2012, 06:52 AM
TNXR's Avatar
I have run my tank down to the low fuel light 3 times now and the tank took about 4.2 gallons to fill it up each time. This was around the 170 mile mark on two of those fill ups but one was at about 135 miles but still roughly a little over 4 gallons to fill it up so go figure! My cheap little suzuki has no fuel gauage but the low fuel light comes on at around the 170 mark every time (bike gets about 52 mpg's).
2011 Cross Roads Sunset Red
OEM short windshield, passenger backrest, crash bars, saddle bag bars, heated grips, vinyl closeouts, tachometer, ambient temp. WD lay down licence plate.
TNXR is offline
post #87 of 158 (permalink) Old 12-15-2012, 09:57 AM
I'm a strong believer that the inaccurate fuel reading has nothing to do with the fuel unit. I believe it has to do with the inaccuracy of the speedometer/odometer. With bad information in, you can only produce bad information.
Ride safe.
2011 CrossRoads
D&D pipes, PCV, Llyodz performance filter w/strip in place, Llyod's timing wheel (set +4) and various other visual do dads. :cool:
vagabondjpm is offline
post #88 of 158 (permalink) Old 12-15-2012, 09:53 PM Thread Starter
Ride safe.
How far off is your speedometer?
My speedometer shows the same speed as my Garmin. The trip gauge is also within 3/10 mile with the Garmin for each tank of fuel.
drummer12345 is offline
post #89 of 158 (permalink) Old 12-15-2012, 10:18 PM
Mine is 10% off. It is aggravating but I've learned to live with it.
Ride safe.
2011 CrossRoads
post #90 of 158 (permalink) Old 12-15-2012, 11:11 PM
Ride safe.
You gas gauge is off by 10% or you speedometer?
60= 66 or 60=54
That is unsatisfactory and should not be "lived with"
orbiker is offline
