2012 CCT HID light fogging - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 10-18-2012, 06:44 PM Thread Starter
Hey guys, I wanted to ask others that have the stock HID light on a 2012 cross country tour if inside the lens fogging up is normal? Mine has been that way for quite a while. Does anyone else have this problem?
Thanks
2012 Red Cross Country Tour
NH4ME is offline
post #2 of 10 (permalink) Old 10-18-2012, 07:23 PM
CrossRoads's Avatar
Thanks
No, it's not normal. And no, it doesn't have anything to do with the HID. You need to remove the headlight, look for any shifted or broken seals, any other openings and seal them up. Silicone is a good option. The heat in the headlight ends up drawing moisture from the ambient air - that's how and why it fogs up.
CrossRoads is offline
post #3 of 10 (permalink) Old 10-19-2012, 05:15 AM Thread Starter
Ok, that makes sense. My bike is still under warranty and was recalled for the throttle cable nuts to be re-torqued. When I take it back for the recall I will have them fix the leak in the headlight. Thanks for the response.
NH4ME is offline
post #4 of 10 (permalink) Old 11-20-2012, 10:05 PM
TheMike's Avatar
Did they fix it for you?
Different model but same problem?
I had a crap load of moisture in my assembly today. Rode to work in below freezing temps. It sat in the warm sun all day and it was 70 when I went out to ride her home.
This is what mine looked like.
The whole assembly is only a few weeks old as the dealership installed it before I picked it up. I do have the original
2012 #20 NESS Vision DARKSIDE BABY!
Stage 1 w/D&D pipes + lots of Victory add ons. PC-V w/AT, Lloyd's intake, filter, ATS, & Variable Clutch.
2013 Bushtec Entourage in matching Ness color and graphics - See the PAINTED TO MATCH process
Wife rides a 2016 Gunner
LONGMONT COLORADO
TheMike is offline
post #5 of 10 (permalink) Old 12-11-2012, 07:46 PM
TheMike's Avatar
Update on mine. I discovered when I installed my VictoryHID bulbs, the dealership installed the rubber cover/boot covering the Vic HID light only half way. That meant for the wash they did and the wash I did after getting her home allowed water and junk to enter the housing. Water poured out of it after I removed the housing from the bike.
All good now!
Sent from my iPhone using Motorcycle.com App
LONGMONT COLORADO
TheMike is offline
post #6 of 10 (permalink) Old 12-12-2012, 04:53 AM
gibson's Avatar
Service department " Fail"
2012 Fireball Jackpot
gibson is offline
post #7 of 10 (permalink) Old 12-12-2012, 07:25 AM
GatorJoe's Avatar
When your headlight gets like this know have a moisture problem ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is online now
post #8 of 10 (permalink) Old 12-12-2012, 08:38 AM
TheMike's Avatar
No kidding. My water pool wasn't visible because of the vision assembly. All below the reflectors.
You check the bulb cover? That's too much accumulation for a small leak, IMHO
LONGMONT COLORADO
TheMike is offline
post #9 of 10 (permalink) Old 12-12-2012, 06:12 PM
GatorJoe's Avatar
This was on my 09 Ultra after riding 12 hours straight in the rain .. When pulled the head light assembly found out the seal was offset
post #10 of 10 (permalink) Old 12-12-2012, 06:14 PM
TheMike's Avatar
That explains it. Hope others check that if they have moisture in theirs.
LONGMONT COLORADO
TheMike is offline
