Aftermarket Handlebars: New Wire-Tie Clips/Holes? - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 11-23-2012, 09:46 PM Thread Starter
wspollack's Avatar
Default Aftermarket Handlebars: New Wire-Tie Clips/Holes?
You folks with aftermarket handlebars: did you buy a new set of clips -- the ones that hold the bundle of cables going to each grip?
These clips go into a hole drilled in the underside of the handlebars, and it looks to me like the factory clips can't be taken out of those holes and re-used. It also looks to me like they may be important, to keep the cable bundles from rubbing the top of the gas tank, if you have the bars fairly low (as my current OEM bars are). Finally, it's my understanding that most or all aftermarket handlebars don't have those holes in them, so if you do have to buy new clips, then you'll also have to drill the holes.
I'm thinking about getting new bars, and I'm trying to get my ducks in a row for this possible winter project. So I'd appreciate any and all comments regarding the clips and anything else you think I should know before tackling this project. (I've already removed the fairing and dash, to add a horn, and that didn't seem like a big deal to me.)
Cheers,
Bill P.
2012 XCT: HeliBars; Centramatics; PC-V; Lloydz air filter; 11" Madstad windshield; Rivco LED mirrors; Doran TPMS; Stebel horn; Motolights; CustomLED trunk flasher; KewlHeel shifter; CycleOps trunk rack; BeadRider seat; Vibranator bar ends; Passenger grab handles; Powerlet outlets; Handlebar RAM mount; RicZ laydown plate; Brukus SaddlebagSecure; 14" flexible antenna; RAM cupholder on trunk; shock Schrader valve relocation.
wspollack is offline
post #2 of 5 (permalink) Old 11-23-2012, 10:14 PM
You could always use chrome zip ties around the bars and black zip ties around the cables and through the chrome zip ties.
Using those clips and drilling some holes would probably be cleaner though.
post #3 of 5 (permalink) Old 11-24-2012, 05:53 AM
Bill--
The 2" pullback bars from Victory come with new cable ties. If you need more, though, google "push mount cable ties." You can also buy them at any H-D dealer.
2012 XCT White
San Antonio, TX
Honda CB350, Penton 125, Penton 175, Honda MR 175, Honda TL250, Yamaha IT 175, Husky 250CR, Husky 360 Auto, Husky 390WR, BMW R90/6, Honda CX 500, 84 Goldwing, 93 Goldwing, 98 Goldwing, 2012 Victory XCT
thumbgone is offline
post #4 of 5 (permalink) Old 11-24-2012, 05:56 AM
jaysonL's Avatar
IMO.....If you're getting new bars, get a set that is drilled and dimpled for internal wiring. I hate that Victory won't do that anyway.
2009 Kingpin 8 Ball
Freedom Performance sharp curve radius pipes
Cross Roads bags mounted with Witchdoctor brackets
Kingpin tour tins
jaysonL is offline
post #5 of 5 (permalink) Old 11-25-2012, 07:22 PM Thread Starter
wspollack's Avatar
Thanks, everyone, for the feedback. I'm still thinking about this (and may continue to do so for the next few months).
Cheers,
Bill P.
