relocated my key switch - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 33 (permalink) Old 12-05-2012, 12:02 PM Thread Starter
Default relocated my key switch
moved the key switch, bought the plate and harness wires from witchdoctors.com,
spoons asmc
spoons-asmc is offline
post #2 of 33 (permalink) Old 12-05-2012, 12:41 PM
ALStensby's Avatar
I just completely removed mine all together.
Adam
2011 Victory Cross Roads - His
2014 Indian Chief 'Springfield' - Hers
ALStensby is offline
post #3 of 33 (permalink) Old 12-05-2012, 01:54 PM
gibson's Avatar
I am not use to the set up of Polaris. My other bike had it up on top with out a key to mess with. Only time you use a key is to lock the ignition. Most of the other bikes I have owned the key was between the bars and tank. I do not reaching down to shut it off. I am in the process of doing it different also..
2012 Fireball Jackpot
gibson is offline
post #4 of 33 (permalink) Old 12-05-2012, 05:01 PM Thread Starter
Default switch
2 things i dont like about victory, the key switch and the exhaust , i changed both
spoons asmc
post #5 of 33 (permalink) Old 12-05-2012, 09:30 PM
Any concerns about engine heat building up?
drummer12345 is offline
post #6 of 33 (permalink) Old 12-05-2012, 09:31 PM
What do you use instead?
post #7 of 33 (permalink) Old 12-05-2012, 11:05 PM Thread Starter
Default key
heat on nothing
exhaust on you tube 2011 victory xr exhaust
post #8 of 33 (permalink) Old 12-05-2012, 11:33 PM
Default heat sheild?
Spoons-asm is there a cover over the wiring on the relocated ignition switch. It would seem the rear cylinder exhaust pipe would over heat or slowly cook the wiring and the ignition switch without some-type of heat shield to protect them.
Speedblue is offline
post #9 of 33 (permalink) Old 12-06-2012, 12:10 AM
bcflyguy's Avatar
Send a message via MSN to bcflyguy
how does it start? How did you bypass the key?
bcflyguy
Kelowna British columbia Canada
1 2012 cross country tour arlin ness big honkers/ fuel controler/air mod, Bag rails, Ostrich 2 up custom seat, Sheepskin seat cover, trunk rack. Bag locks
2 2013 cross country tour . Trunk removed. ness honkers lloydz air box, bag rails Rich's custom gel/ ostrich seat .Bag locks. chrome pass boards. Ignition relocate.Kury mirrors,
bcflyguy is offline
post #10 of 33 (permalink) Old 12-06-2012, 03:49 AM
GatorJoe's Avatar
Just installed a Digital Guard Dawg .. Keyhole is still there but just need the FOB in my pocket now to Fire it up ..
2012 Victory Cross Country, Freedom Performance Duals, Lloyds Filter, ATS+4, VM1 Cams ,PCV Tuned by KMC .. 2015 Indian Scout, Stage1 Tuned by KevinX
GatorJoe is offline
