Broggy's Winter Work 2016-2017 - Victory Forums - Victory Motorcycle Forum
 361Likes
post #1 of 378 (permalink) Old 12-11-2016, 07:27 PM Thread Starter
Instead of clogging up the "What did you do today" thread, I figured I'd make my own. Easier to find and update.
Anyway, today I tore the bike apart. I need to pull out the starter because it squeals like a whiny bitch when its cold. Also, I have a brand-new PCV to be installed, and I want to (re)install my iPod cord (from when I removed my lowers).
It was 17 degrees when I woke up; good thing I didn't have to work today. First thing I did: fired up the kerosene heater!
Removed the exhaust and pulled the starter. No rust in there (whew!), but lots of iron filings. Cleaned everything out, cleaned and regreased the bearings, and reassembled the motor. So far, no more squeals!
Next up:
Removal of the VFC III and installation of the PCV... (stay tuned)
ATS+4 & filter, PCV, Memphis Shields fork wings, Madstad Windshield
Painted wedges w/LEDs & derby cover, center fork air deflector
PBR300X4 Amp, Polk DB522 fronts, Dayton Audio ND140-4 + tweeters rear
No Cats, CREE LED, Ultimate seat, 90.8 HP, 105.7 TQ w/ OEM mufflers!
HyperLites, Quad-LED driving lights, Hydraulic Clutch
KlockWerks KlipHanger bars, Avon grips, Kury Sabertooth LEDs
THE FEW, THE PROUD, THE OBSCURE
broggyr is online now
post #2 of 378 (permalink) Old 12-11-2016, 07:58 PM
doobliss's Avatar
It was 17 degrees when I woke up; good thing I didn't have to work today. First thing I did; fired up the kerosene heater!
Next up:
That looks like some great progress Broggy! Kudos!
Side note, I'm oddly elated to see that my bike is not the only one with a dirty engine.
'15 Gloss Titanium XC.
WOLO Low Tone Disc Horn (Thanks Vindex)
Vance+Hines High Output Slip Ons
Black LED Headlight
Kingpin Metal Fork Guards
Ricz Lay Down Plate
Lloydz Timing Wheel & Throttle Ring
Shinhopples Grip Covers
12" Long Ride Shield
CFAD (Thanks Jjpilot)
Ness Signals; Amber front, Red rear
http://www.pure-gas.org/
"I leave the BUG CARNAGE on my screen , it adds character!"-LILMAGS500
doobliss is offline
post #3 of 378 (permalink) Old 12-11-2016, 08:09 PM
Good job and all accomplished with a mallet, screwdriver, vice grip and crescent wrench.
2010 Midnight Cherry XR. 7Jurock, Lloydz AF, ATS, VFCIII, IAV, and T-6 and locally repacked pipes = big smiles.
+ For the best and cheapest Cross bike license plate laydown bracket, click this:http://www.victoryforums.com/showthr...=riczsifieds/+
post #4 of 378 (permalink) Old 12-11-2016, 08:22 PM Thread Starter
Don't forget the WD-40!
RICZ likes this.
post #5 of 378 (permalink) Old 12-11-2016, 08:32 PM Thread Starter
So, the biggest question in my mind regarding this starter rebuild was "How am I going to hold back all of those brushes at the same time?" when it came time to reinstall the armature. I watched many videos. Every single video I saw all had the brush plate separate from the end cap. Did you know the Vic starter brush plate is bolted into the end cap? I didn't have anything springy or clampy enough to hold these back. I was in a bit of a pickle. In the back of my mind, I figured I'd probably have to buy a new starter.
One of the videos I was watching was for a Briggs-and-Stratton starter. The guy said you could buy a new brush plate and end cap as an assembly, the brushes were held back by baling wire. This got me thinking. So I took a look at the brush plate in the Vic starter and sure enough, there are small recesses that would be perfect to stick in a paperclip.
So, I took 2 paperclips, straightened them out, then cut them in half so I had 4 equal-sized pieces about 2 inches long each. I was able to push a brush back into its holder, slide it all the way back, and hold it into place with the paperclip piece. I was able to do all 4 brushes, slid in the armature, then pulled the pins out.
Worked like a CHARM.
Then, I realized I forgot to replace a couple of the bushings; I had to do it all over again. The sweet thing was, it was just as easy to do it all over again.
I only wish I had thought to stop and take photos; I was so excited that it was actually working...
Now, I just hope that what I did fixes that god-awful noise when it's cold out. It's certainly better than buying a new one for $75-100 (aftermarket).
post #6 of 378 (permalink) Old 12-11-2016, 08:44 PM
Where there's a will there's a fix. Dontcha just love those work-arounds. Sometimes a repair job is 30% thinking, 70% wrenching.
SemperVee, BenD, broggyr and 1 others like this.
post #7 of 378 (permalink) Old 12-12-2016, 10:32 AM
kodiakwood2's Avatar
Nice work Brian
Eastern Tennessee
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
post #8 of 378 (permalink) Old 12-12-2016, 11:17 AM
Your way to fast to keep up with. New brushes cheap. Hope you cleaned the armature
.13" x .30" x .41" x .5" 8275528-S BRUSH KIT " WEDGE" SHAPE BR687800
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton
No Polaris ever again
Don't Text and Drive
post #9 of 378 (permalink) Old 12-12-2016, 12:45 PM Thread Starter
The brushes were fine. Armature/commutator was also cleaned
Not sure why I'd want to put in wedge-shaped brushes...
post #10 of 378 (permalink) Old 12-12-2016, 01:28 PM
vindex1963's Avatar
Those "aftermarket" starters aren't aftermarket they are the exact same ones Victory uses right down to the numbers stamped on them. I bought one for my Vegas the same one Vic wants $100's for and it was an exact match.
2015 Cross Country
2015 Suzuki V-Strom DL650
vindex1963 is online now
