Check engine light after disconnecting o2 sensors - Victory Forums - Victory Motorcycle Forum
 11Likes
post #1 of 26 (permalink) Old 02-11-2017, 07:41 PM Thread Starter
tcrider's Avatar
Default Check engine light after disconnecting o2 sensors
Hi all, new to the forum and already bringing questions...
So, I disconnected the sensors and got the engine light on the bike, I have a 17' magnum and I cant find anything on the web relating this issue.
Also wanted to confirm that this is not a bad move on my part being that I just reach the 500 mile break in period.!!
I wont stand riding with the light on even if this is not an issue. Please let me know if this common.
Thanks in advance.
Ride safe everybody!!!
tcrider is offline
post #2 of 26 (permalink) Old 02-11-2017, 08:29 PM
You need O2 eliminators for the 16's on up to shut the light off.
2013 xct bronze
VM1 DR-T "Touring" cams
Lloydz air filter
Timing wheel at 5 deg
Quarter turn throttle
D&D's wrapped
Tuned from The Vic Shop 8/14/15
Dyno 123hp 117tq
Led headlight
Digital guard dawg
HMD gorilla bagger bars
Centermatic wheel balancers
Hydraulic clutch
2015 xct black wife's
Leman crossfire trike kit
Quarter turn
Big gonzo mufflers
2 inch pull back bars
Vm1 cams
Air filter
Timing wheel +2
Pcv
Properly tuned by the vic shop on the street
refuse2 is offline
post #3 of 26 (permalink) Old 02-11-2017, 09:38 PM Thread Starter
tcrider's Avatar
Great!!!
I'll start searching for those, in the meantime is fine to run without the eliminators, right?
Thanks for the prompt response.
tcrider is offline
post #4 of 26 (permalink) Old 02-11-2017, 10:29 PM
djh3's Avatar
The ECM is doing exactly what its supposed to. Telling you something is wrong with the engine. At least in its opinion. Everything is programed to have those O2 sensors give feed back to the ECM so it regulates the fuel injection correctly, adjusts the timing, and burns off the bad stuff in the CATS. Once you disconnect them, now the ECM goes "Houston we have a problem" and lets you know by turning on the warning lite. With the O2 disconnected it dumps more fuel than needed, so mileage goes down. Also because you are now putting more "raw fuel" into the cylinders it dont all burn. So you get unburned gas in the Cats, so they run hotter to burn off the unburned fuel. If you punch out the CATs it kind of goes the other way. It leans out, which makes the Cylinders run hot because some of what the fuel does is cool the cylinders.
2013 XCT added Jan 2015
pull back bars, passenger arm rests, Silverstar Ultra headlight,Drag Specialties Pillow Top seat with driver backrest.
djh3 is offline
post #5 of 26 (permalink) Old 02-11-2017, 11:13 PM Thread Starter
tcrider's Avatar
Ok. So if I understand correctly, this is not a good idea since I pulled the baffles completely out of the exhaust, right?
I apologize if I ask stupid questions, just want to make sure I dont hurt my bike in the long run.
tcrider is offline
post #6 of 26 (permalink) Old 02-12-2017, 05:59 AM
I have a 2017 Highball. I used the plugs supplied by Dobeck. Dobeck plugs are a single capacitor plug for the O2 sensor. Check engine light still comes on after installing plugs. Not sure what the difference is in the 2017's. PC5 has a double capacitor plug for the O2 sensor with their set up and might give them a try.
aor98 is offline
post #7 of 26 (permalink) Old 02-12-2017, 06:23 AM Thread Starter
tcrider's Avatar
So I decided to connect them back until I get the plugs, the codes are gone but the check engine light still on. Is there a way to reset it? Or should I wait a little longer and it will disappear? Thanks for letting me know about the dobeck plugs, I thought that they fixed the engine light problem. I guess I'll keep researching.
tcrider is offline
post #8 of 26 (permalink) Old 02-12-2017, 06:24 AM
half_crazy's Avatar
Originally Posted by tcrider View Post
I have a 17' magnum
You have a 17 foot Magnum?
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #9 of 26 (permalink) Old 02-12-2017, 06:43 AM Thread Starter
tcrider's Avatar
Haha. That is funny!!! Any comments on the matter? Other than this?
tcrider is offline
post #10 of 26 (permalink) Old 02-12-2017, 06:53 AM
LILMAGS500's Avatar
I have a 3" Magnum ....
LILMAGS500 is offline
