Howdy, new guy here. I've recently purchased a 2017 Magnum and upgraded it to the X1 package which adds a second 100 watt amp and saddle bag speakers to the front 100 watt amp and 6 dash speaker set up. I also added the accessory trunk which ALSO has a pair of speakers in it. The unfortunate thing is once you connect the saddle bag speaker connection, the only plug available is used and there is no way to plug up the trunk to get the speakers, high mount tail/brake light, and acc power socket in the trunk to work. Has anyone done this in a plug and play method? I'm actually satisfied with the stock sounds I just want to add the trunk speakers into the mix along with the other electronics in the trunk. I know not many folks have added a trunk onto a Magnum, but I thought I'd give a shout out and see if there were any suggestions. I've already done several searches but haven't found any threads with that information in them.
