What scrapes first? - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 11-01-2010, 07:36 AM Thread Starter
Default What scrapes first?
I love to ride aggressively in the curves, but at the same time I don't like surprises in the middle of them, so I'd like to know what's the first thing that scrapes on an XC? From outward appearances it'll be the massive highway bars, which wouldn't be too forgiving and probably end up being quite expensive, and possible painful. My Roadking gave me ample warning with the floorboards hitting first, but I still knew I had about five more degrees of lean angle before anything "Hard" scraped. I'd really like to push the XC harder, especially since it seems to beg for it, but I don't cherish the idea of learning the hard way. Thanks.
Expat in Germany
2011 Cross Country
2002 Roadking
2001 Softail Standard (wife's)
Expat is offline
post #2 of 15 (permalink) Old 11-03-2010, 01:49 AM Thread Starter
Hey folks, what gives? No one here ever scrape anything in the twisties?
Expat in Germany
2011 Cross Country
2002 Roadking
Expat is offline
post #3 of 15 (permalink) Old 11-03-2010, 06:59 AM
gulliverstoe's Avatar
howdy xpat..
from the sound of it, your break in ride went ok,
as for scraping...for me not so aggressive in the twists but sometimes in low speed corners i scrape the boards - just a tad...cause they have very little travel...compared to my honda and nc-paladins for example...now then, 2 up with 0 air in the shock, in similar low speed turns...it is the tail end of the tail pipe that scrapes...so now i am running about 15 lbs...i think...to continue, the air pump seems useful as a backup inflation tool for flat repair (stop-and-go mushrooms and c02 here)
Tucson
2010 XCountry
gulliverstoe is offline
post #4 of 15 (permalink) Old 11-03-2010, 02:06 PM
The first day I bought my Crossroads, my wife and I went for a ride. I should have added air in the suspension (I do now). We were making a sweeping right hand merge. I scraped the right rear heat shield on the exhaust. You have to get low and look up on the exhaust to see it thank God! But, definitly put air in the suspension for the appropriate weight!
Gonzo18 is offline
post #5 of 15 (permalink) Old 02-08-2011, 09:38 PM
Does anyone know what the actual maximum lean angle is? HD publishes their's per SAE J1168. Does Victory?
Outlander is offline
post #6 of 15 (permalink) Old 02-09-2011, 11:13 AM
For low speeds check out the Police videos
http://www.victorypolicemotorcycles....icevideos.html
tom
sanqhar is offline
post #7 of 15 (permalink) Old 02-09-2011, 11:32 AM
warr110r's Avatar
Those are some great videos that confirm the performance of this great bike.
2011 Blue Cross Country
Arlen Ness RAD III Mirrors
Bassani 4" Mufflers
Stablemate:
2002 Yamaha Warrior
110 C.I. Patrick Racing Kit
Waay too many other Mods
warr110r is offline
post #8 of 15 (permalink) Old 02-09-2011, 12:24 PM
I guess I have myself to blame for the responses I'm generating. I should have started a new thread to ask my question rather than revive this old one.
I'm interested in what the SAE J1168 lean angles are for these bikes.
Thanks
post #9 of 15 (permalink) Old 02-09-2011, 02:34 PM
Why don't you have a buddy come over start the bike and then one of you lean it over. You can find out when it quiets and what would hit first.
For some reason I'm thinking if you get over so far that the lean sensor works you'll be crashing and it doesn't matter then now does it.
post #10 of 15 (permalink) Old 02-09-2011, 03:03 PM
Default Max lean angle
How's this look?
2010 Midnight Cherry XR. 7Jurock, Lloydz AF, ATS, VFCIII, IAV, and T-6 and locally repacked pipes = big smiles.
+ For the best and cheapest Cross bike license plate laydown bracket, click this:http://www.victoryforums.com/showthr...=riczsifieds/+
