Victory Cross Country Recall - Page 2 - Victory Forums - Victory Motorcycle Forum
 1Likes
post #11 of 21 (permalink) Old 06-13-2011, 10:57 PM
Originally Posted by ndabunka View Post
Everyone here may want to hold off a bit. According to another Victory forum, this is not yet "official" which is why they don't have anyone's VIN #'s associated with the bulletin. Basically, it appears that the "bulletin" has not yet been posted on Victory's internal database so calling them at this point won't get us anywhere (as we have seen).
Good point. New to Victory's and have not even had time to really ride ours since purchased so this was the last thing I wanted to read about. However, before hitting the panic button and calling my dealer, I read your post and sometimes patience is the best avenue.
2011 Black Victory XC
Trunk
+3" Shield
mxfan69 is offline
post #12 of 21 (permalink) Old 06-13-2011, 11:35 PM
Unless you can move the bars without a whole lot of effort; there's no big deal going on. Trust me, if this was as bad as some people make it out to be, the owner of the bike would be down at the dealership asking them some questions because the bars would be moving around on them.
post #13 of 21 (permalink) Old 06-19-2011, 07:47 PM
Had a message on the answering machine from the dealer requesting mine be brought in as the manuf date fell in the range. Worked good for me as I was already scheduled for the 500 mile first service yesterday.
I watched thru the shop bay door and two mech's hooked scales (kind'a like a fish scale) to the handle bars, one on each side. They marked the bars near the riser clamps and both lifted upward on the scales until both scales read 50lbs each. The bars didn't move, one guy gave me a thumbs up as the other checked the throttle (main part I DID NOT like was it being hooked to my throttle/tube) to make sure it was not in a bind. They gave me a copy of the paperwork and said goodbye.
I was a little confused by the pounds of force used as I swear the first service guy said the service recall said 50lbs of force total (25 per side right?). So I am thinking about it correct, right, they pulled both scales to 50lbs EACH, that makes 100lbs of force they put on the bars......right? Oh well, eitherway they did not move
Trunk
+3" Shield
mxfan69 is offline
post #14 of 21 (permalink) Old 06-19-2011, 08:30 PM
CrossRoads's Avatar
Originally Posted by mxfan69 View Post
... So I am thinking about it correct, right, they pulled both scales to 50lbs EACH, that makes 100lbs of force they put on the bars......right? Oh well, eitherway they did not move
You are correct. Two applications of 50 pounds each result in a total applied force of 100 pounds. They might be applying more force than what the minimum is in order to make sure you're well over the minimum requirement. Safety first!
madesertrat likes this.
CrossRoads is offline
post #15 of 21 (permalink) Old 06-23-2011, 12:30 PM
It's official... I got my recall notice in the mail yesterday. My bars seem to be solid, so I'm not going to worry too much but I will make sure to get the bike in as soon as reasonable.
Dave
2011 Black XC
Tualatin, Or
dbrock950 is offline
post #16 of 21 (permalink) Old 06-24-2011, 06:23 AM
RedRocker's Avatar
Post
Same here. Third paragraph in the recall letter states:
[B]What Victory and your dealer will do:
Victory has issued Safety Recall Bulletin V-11-01 to all Victory dealers, with instructions required to test and replace defective riser/clamp assemblies that provide insufficient clamping force. Repairs will be made by any authorized Victory motorcycle dealer at no cost to you. If handlebar riser/clamp replacement is required, the actual repair should take under 2 hours to perform; however, it may take longer due to service scheduling requirements.
Calling my shop later today.
Dave
USCG Retired
2014 Sonic Blue/Silver XCT
Lloydz VM1-DR Cams/ATS/Air Filter/.25 Turn/PCV/Vic BlkTip Tri-Ovals/Tuned by KMC Powersports: 111/112 CR's H/L HID Kit/Glenda LED's/Hyperlites/Stebel Air Horn/Vic Black Billet Floorboards-Primary&Cam Cover
2011 XC-Traded
RedRocker is offline
post #17 of 21 (permalink) Old 06-24-2011, 03:10 PM
Got my letter yesterday. I went out per the letter and pulled up on the bars...seems pretty solid but i will take it in at some point.
Ranman:cool:
2011 XC (Black)
2007 KP Tour (Graphite & Pearl) Traded
Suzuki GT750 (Water Buffalo) Purple/White
1973 Kawasaki 90 street (1st bike)Kawasaki Green
Ranman is offline
post #18 of 21 (permalink) Old 08-01-2011, 11:19 AM
Default Here's is what I was told....
I took my XC in for the recall (as Victory said it was on their list). The tech checked it and said they were good. I asked what the recall was in reference to and he stated the following:
There were a few bikes that had problems with the bushings that the handlebar risers mounted in to. These are rubber bushings that have steel outer and inner sleeves. They are pressed into the triple tree with 8,000lbs+ of force. The "test" for failure is to pull up and pull down on the bars with 50lbs of force. So far, they have not had any bikes that required repair.
This sounded a bit strange, but the issue seems to be that the bushing could be defective and would allow to riser to rattle around and/or slip.
So, as one other post stated, you can give the bars a strong pull and if they don't move -- you are probably good.
texantildeath is offline
post #19 of 21 (permalink) Old 08-04-2011, 08:50 AM
Called Victory today 8/4/11. They said the recall is complete.
2011 White and Silver Cross Country
Bastrop70 is offline
post #20 of 21 (permalink) Old 12-11-2012, 10:04 PM
bcflyguy's Avatar
Send a message via MSN to bcflyguy
Victory Cross Country Recall. A recent recall announcement filed with the National Highway Traffic Safety Administration include reports of flawed motorcycle handlebar assemblies on certain Victory Cross Country motorcycles from the 2011 model year that could cause riders to suddenly lose control. Problem comes from improperly machined handlebar clamps or risers, and as a result the clamps could allow the bars to move or slip unexpectedly with such a sudden movement of the handlebars possibly leading to a crash. The recall affects 840 bikes built from Jan. 1 through April 11 of this year. Polaris says its dealers will replace defective riser and clamp assemblies free of charge. The recall is expected to begin this month. Owners may contact Victory at 888-704-5290.
Are there any other recalls recently on 2012 XTC. Can a Canadian bike get the recall done in the USA???
Kelowna British columbia Canada
1 2012 cross country tour arlin ness big honkers/ fuel controler/air mod, Bag rails, Ostrich 2 up custom seat, Sheepskin seat cover, trunk rack. Bag locks
2 2013 cross country tour . Trunk removed. ness honkers lloydz air box, bag rails Rich's custom gel/ ostrich seat .Bag locks. chrome pass boards. Ignition relocate.Kury mirrors,
bcflyguy is offline
