How does the Hammer "Handle" versus the Suzuki M109R?? - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 11-14-2012, 11:13 AM Thread Starter
Default How does the Hammer "Handle" versus the Suzuki M109R??
Hello,
I actually sold my M109R because I just didnít like the way it handled. It just felt uncomfortable through turns. Iím attributing a lot to the 240mm rear tire.
Iíve been looking around for a vegas or a highball, BUT came across a hammer at a great price.
Iím a little hesitant because of my experience with the m109r. Can anyone speak to the handling difference between the hammer and the m109r?
Iím trying to see if I can test ride a hammer this weekend. But Iím hoping to get input from folks on this board as well.
THANKS!!
phatjoe is offline
post #2 of 8 (permalink) Old 11-14-2012, 12:36 PM
07PEARLJACKPOT's Avatar
test ride all three,all victory dealers will let you
test ride their bikes. from my experience i have
rode all three and the highball wins hands down!
KURYAKYN LED BLINKERS
GUNFIGHTER SEAT
KURYAKYN FLAME COMFORTGRIPS
KURYAKYN FLAME PEGS
"JACKPOT" OIL COOLER COVER
CHROME STARTER COVER
MEMPHIS SHADES WINDSHIELD
VICTORY TOOL ROLL
RPW SLASH EXHAUST
S&S INTAKE
KURYAKYN ELLIPSE MIRRORS
07PEARLJACKPOT is offline
post #3 of 8 (permalink) Old 11-14-2012, 12:50 PM
I came from a 9. The Hammer has a 250 rear so ithinking that the handling is going to be the same. On my 9 I put on the 250 rear and a 160 up front and it made a huge difference in handling. I havent checked to see what the Hammer is running up front.
Mark
11 XC
Las Vegas,NV
Vegas Bagger is offline
post #4 of 8 (permalink) Old 11-14-2012, 01:55 PM
half_crazy's Avatar
The 109 has shaft final drive and that adds a considerable amount of unsprung weight. The suspension is better on the Hammer and the unsprung weight is less so the rear suspension controls wheel movement better. Still requires more steering effort than the bikes with 180mm or smaller rear tires, but not as choppy of a ride as the 109.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #5 of 8 (permalink) Old 11-14-2012, 06:46 PM
Marius's Avatar
If the rear tire was the problem on the previous bike chances are it will also be the same on the hammer.
2007 Victory Hammer (Nuclear Sunset)
2012 Vstrom Adventure 650
2006 Suzuki M50 (Black) - Traded
1995 Mustang GT... Work in Progress...
Marius is offline
post #6 of 8 (permalink) Old 11-16-2012, 12:51 PM
Mr_Buzzcut's Avatar
It took a few rides to get used to but I think the hammer handles nice. BTW I have the Hammer S with the pulled back bars. They say the Hammer with the V bars doesnt handle as good because you have to reach for them.
2008 Hammer S
300mm Fat tire
USMC 87-92
Mr_Buzzcut is offline
post #7 of 8 (permalink) Old 11-16-2012, 01:45 PM
Marius's Avatar
This is true. I am actually in the process of converting my Hammer to a Hammer S seating position (which only involves handle bar mod and footpeg extensions)
I did the footpegs already and absolutely love how that changed my feel position. I feel much better planted on the bike now.
I'm going to install 2inch risers to raise the factory v bars next, and then probably swap over to the jackpot handle bars if the risers don't provide enough pullback. I do like the look of the v bars, so I will try to make them work if I can.
But regardles... some riders never get use to that big tire, so if that was your main issue on the 109 then you could still be turned off by the tire on the hammer. Best thing to do is test ride a few miles.
Marius is offline
post #8 of 8 (permalink) Old 11-16-2012, 06:44 PM
TNXR's Avatar
I know it is not the same but I have M50 with a 200mm tire and it really hurt the handling in the twisties but it does look cool. I agree that a 180 is about as big as you want to go on the back and still have a great handling bike.
2011 Cross Roads Sunset Red
OEM short windshield, passenger backrest, crash bars, saddle bag bars, heated grips, vinyl closeouts, tachometer, ambient temp. WD lay down licence plate.
TNXR is offline
