need some help, please rear axle nut - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 11-20-2012, 09:11 AM Thread Starter
Default need some help, please rear axle nut
Hello, I can't seem to find the size of the rear axle nut in the manual. I assume that it's metric but not sure and I want to go buy a socket for it. Can someone tell me what size the nut is for the rear axle nut? 2012 Cross countryThanks,LongRIder
1997 E-Glide (rebuilt @ 100k) Hillside stage II heads, Woods 6 cam, balanced crank, Weiscos, 40mm CV, Thunderheader.Tuned by Hillside.
2012 XC w/ Ipod cable, Klockwerks windsheild, D&D's, air filter, stage 1 flash.
LongRIder is offline
post #2 of 11 (permalink) Old 11-20-2012, 10:31 AM
i believe you need a 27mm crowsfoot. do a search, there's several threads on it.
now , 2011 crossroads and 05 sportster bobber in the making
in order of ownership, sears compact scooter, honda 305 scrambler, honda 160 dream , triumph 500 trophy trail, honda cb450, sportster, honda f750, 2nd sportster, harley flh, harley super glide, 3rd sportster, bmw k1000, harley low rider, 2nd harley super glide, harley heratage, harley road king, bmw r1150rt,
thats just the street bikes!
ridealittle is offline
post #3 of 11 (permalink) Old 11-20-2012, 12:48 PM
CrossRoads's Avatar
1-1/16" nut, to be torqued to 65 ft·lbs.
CrossRoads is offline
post #4 of 11 (permalink) Old 11-20-2012, 12:57 PM
dtmmil's Avatar
Yes, 1 1/16" or 27mm, you can get a wrench in there from the bottom at the back without taking the bag off, but its almost easier to take the bag off.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 11 (permalink) Old 11-20-2012, 02:07 PM
TNXR's Avatar
If you plan on torqueing it down then you will need the 27mm crowsfoot and adjust your lb's for the extra length. It is 57 lbs for my torque wrench and crows foot (the being if my torque wrench is still accurate).
2011 Cross Roads Sunset Red
OEM short windshield, passenger backrest, crash bars, saddle bag bars, heated grips, vinyl closeouts, tachometer, ambient temp. WD lay down licence plate.
TNXR is offline
post #6 of 11 (permalink) Old 11-20-2012, 04:04 PM Thread Starter
I do plan on torquing the nut to the proper setting. If I buy the crowsfoot, is there a formular to figure out what to set the wrench at to get to the 65 ft lbs? Also, does anyone if a fastener listing is available for these bikes? I noticed that the manual does not do a good job of identifyting fastener sizes.
thanks,
LongRIder
post #7 of 11 (permalink) Old 11-20-2012, 04:30 PM
The question is, will a torque wrench still measure accurately if a cheater bar is used on the end? The answer is yes. All this configuration will do is increase the force on the end of the torque wrench. The torque measured by the wrench doesn't care if there is a hand pressing down on the wrench or if a cheater-bar is supplying the force.
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton vote.
No Tapatalk.
Don't Text and Drive ​​
post #8 of 11 (permalink) Old 11-20-2012, 04:46 PM
TNXR's Avatar
There are several places on the web that will provide a calculator, here is one.
http://www.cncexpo.com/TorqueAdapter.aspx
TNXR is offline
post #9 of 11 (permalink) Old 11-20-2012, 08:17 PM Thread Starter
Thank you to everyone that responded. TNXR, Thanks for the calculator too.
LongRIder
post #10 of 11 (permalink) Old 11-21-2012, 07:04 AM
TNXR's Avatar
No problem. If you are adjusting your belt just a warning that when you torque the bolt down it will probably affect the position of the belt on the sprocket. I ended up getting the belt all the way to the left side then a few runs of torque down nut and spin tire then lossen bolt and mess with adjuster nut till I got the belt where it would not run on one side of the sprocket.
TNXR is offline
