Cleaning the 106 engine - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 11-20-2012, 06:44 PM Thread Starter
gamewarden's Avatar
Default Cleaning the 106 engine
Here is my problem I have my bike apart in my basement for mods and a good cleaning. I bought some S100 to do the powder coat and cylinder fins. Unfortunatly I read the can when I got home and found it is highly flammable. Since my bike is parked beside my oil furnace using this product would not be a good idea.
Can anyone suggest a good alternative??
Thanks.
2011 custom Tequila Gold with Candy Orange accents, hard lowers and trunk, Ipod in lowers, HID and saddle bag bars, stage 1, heel shifter, front and back chrome fender guards,Garmin GPS, fairing wind deflectors, heated Gerbing hook up, Dain skull brake pedal, rear brake master and reservoir cover, custom cheese wedge cover, clutch cover, Witchdoctor cam covers, Wolo Bad Boy horn, heated grips and seat, Gorilla alarm, Vision rear engine brackett covers, Kruzer Caddy, WD exhaust tips.
gamewarden is offline
post #2 of 12 (permalink) Old 11-20-2012, 07:12 PM
DTWOR's Avatar
Originally Posted by gamewarden View Post
Here is my problem I have my bike apart in my basement for mods and a good cleaning. I bought some S100 to do the powder coat and cylinder heads. Unfortunatley I read the can when I got home and found it is highly flammable. Since my bike is parked beside my oil furnace using this product would not be a good idea.
Thanks.
S100 is good stuff. The propellant would be flamable but you really don't put that much into the air with the nozzle.If your uncomfortable shut the furnace down when you spray it on your parts.The wifes hair spray is probably more volatile.
2011 Pearl White Vision
IBA #47523
DTWOR is offline
post #3 of 12 (permalink) Old 11-20-2012, 07:15 PM
CrossRoads's Avatar
Roll the bike outside, clean it, then roll it back in.
CrossRoads is offline
post #4 of 12 (permalink) Old 11-20-2012, 07:36 PM Thread Starter
gamewarden's Avatar
Cross Roads
This is Ontario Canada not California cold as hell. I have to remove both patio doors to get it in and out so it is a twice a year thing. Any other products do a good job?
post #5 of 12 (permalink) Old 11-20-2012, 11:35 PM
Bike Spirits; but I don't know about the flammability of it. You can Google it to find a place to look into it.
post #6 of 12 (permalink) Old 11-21-2012, 05:11 AM
Pig Spit works great on the engine and any powder coat.
2012 Sunset Red CCT, D&D's, Cobra CVT, Lloyd's Air Kit, Lloyd's ATS, Lloyd's 1/4 Turn Throttle
basshawk84 is offline
post #7 of 12 (permalink) Old 11-21-2012, 06:18 AM
Send a message via Yahoo to SteveYacht
Get the S100 in the pump bottle instead of the aresol spray. That, of simply turn off the furnace during the small amount of time you are actually spraying. Won't be that long, maybe 5 to 10 minutes.
Charter Life Member AMA
Life Member NRA
Member Legion Riders
U.S. Army Veteran
1968 Honda CB350
1973 Norton 750 Commando
1978 Suzuki 1000
1984 Honda VF700S Sabre
1985 Honda Gold Wing Aspencade
2013 Victory Cross Country
SteveYacht is offline
post #8 of 12 (permalink) Old 11-21-2012, 06:53 AM
jaysonL's Avatar
Yep, just make sure the furnace isn't firing,and you golden.
2009 Kingpin 8 Ball
Freedom Performance sharp curve radius pipes
Cross Roads bags mounted with Witchdoctor brackets
Kingpin tour tins
jaysonL is offline
post #9 of 12 (permalink) Old 11-21-2012, 09:42 AM
Buster's Avatar
This may not help at all but what I use, I got from a relative that does car detailing. Looks just like Armor All, it came in a gallon jug, pour into a spray bottle, spray the motor down that clean up the over spray and the motor looks good. This stuff brings the shine back with out the dirt attracting oil base of the other products. Lasts most of the summer.
Buster
2008 Vision Tour
Buster is offline
post #10 of 12 (permalink) Old 11-21-2012, 10:28 AM
4 inch pistons's Avatar
May be just as flammable, but Sea Foam makes a spray called Deep Creap that is the best cleaner and lube I have found. Brake cleaner is another but it too may blow your house away. I have also found that the no scrub tire foam makes a good all purpose cleaner without a lot of work, but check to see what kind of metal it may affect.
Easier to just move south. (I'm riding tomorrow)
"The Road Goes on Forever and the Party Never Ends"-Robert Earl Keen
4 inch pistons is offline
