Victory reverse issues - Victory Forums - Victory Motorcycle Forum
 10Likes
post #1 of 50 (permalink) Old 04-10-2017, 10:59 PM Thread Starter
DirtyDan's Avatar
Default Victory reverse issues
Is anyone here well versed on Victories reverse? Had some issues today when reinstalling body parts after paint.
Thanks
Dan
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #2 of 50 (permalink) Old 04-11-2017, 07:27 AM
Sorry, Dan. What kind of issues?
ATS+4 & filter, PCV, Memphis Shields fork wings, Madstad Windshield
Painted wedges w/LEDs & derby cover, center fork air deflector
PBR300X4 Amp, Polk DB522 fronts, Dayton Audio ND140-4 + tweeters rear
No Cats, CREE LED, Ultimate seat, 90.8 HP, 105.7 TQ w/ OEM mufflers!
HyperLites, Quad-LED driving lights, Hydraulic Clutch
KlockWerks KlipHanger bars, Avon grips, Kury Sabertooth LEDs
broggyr is online now
post #3 of 50 (permalink) Old 04-11-2017, 07:55 AM
MTVic's Avatar
Let me guess, The left side panel keeps popping off the grommets? Wiring is real bulky. I had to cut a curve in mine around some of the wires to get it to stay on.
Other than that????
Mike
2012 Black XC Tour, HELI bars,
1.5" lowering kit, Closeup Seat, Heli bars, Reverse, "sans cats", ATS, IAV, PC5, m.o.u.s.e...
2nd in command... 2016 Honda NM4
MTVic is offline
post #4 of 50 (permalink) Old 04-11-2017, 09:17 AM Thread Starter
DirtyDan's Avatar
When i turn the key on the indicator shows its in reverse. It is not. I've checked every plug and the fuse to no avail. Plan it now to pull the tank and check wires under there. Also will pull entire harness and go through that. Can't think of anything else.
All sold
2012 XCT,
2003 FLHTCUI
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #5 of 50 (permalink) Old 04-11-2017, 09:36 AM
MTVic's Avatar
Try turning key on, try engaging reverse lever again (may require you to slightly rock bike back and forth to get it into position, LEVER UP) then, take it our of reverse and see if the light goes off. If it won't fully go into up position DON'T FORCE IT!!!
I am assuming as you said lever IS NOT up, and bike won't start. This is a safety precaution as starter button is your reverse.
Happened to me one time when mechanic forced the bike into reverse and. You have to let it go in by itself, sometimes requires this slight forward/back rocking while engaging. Sounds like the engagement rod may have gotten stuck. If so you probably have to take it apart, get it loose, line it up properly and lube.
Mike
MTVic is offline
post #6 of 50 (permalink) Old 04-11-2017, 09:39 AM Thread Starter
DirtyDan's Avatar
Thanks, i've tried that. Even moved it in reverse and heard reverse motor spin. its shows reverse whether lever is engaged or not.
All sold
2012 XCT,
2003 FLHTCUI
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #7 of 50 (permalink) Old 04-11-2017, 09:43 AM
MTVic's Avatar
So can you engage reverse properly? You hear/ feel it go in? If so, does sound like you need to pull the harness connectors and check for good connections. you said you had some parts off for paint /body work and the connectors may have bad contact or damaged sensor. That's how they by pass the starter switch.
Mike
MTVic is offline
post #8 of 50 (permalink) Old 04-11-2017, 09:57 AM Thread Starter
DirtyDan's Avatar
Yes I did that. I can stick my finger in from the end of the pulley cover and feel the gear engaged and disengaged. For some reason it wont shift out of neutral either but maybe that's another issue. I've unplugged every connector except down by the battery and all looks good. I'm also wondering if it's the old Vic dirty battery terminal issue. I will check that also. Battery is at 13.2.
All sold
2012 XCT,
2003 FLHTCUI
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
post #9 of 50 (permalink) Old 04-11-2017, 10:03 AM
MTVic's Avatar
Doesn't sound like battery, sounds like the sensor or connector/electrical. As I remember I don't think the Harness interrupts existing harness, only plugs into an extra one left for the reverse upgrade and the system recognizes it. In either event have you tried unplugging it or basically putting wiring back to original with the electronics of the reverse disabled and then see if light is on?
Mike
MTVic is offline
post #10 of 50 (permalink) Old 04-11-2017, 10:09 AM Thread Starter
DirtyDan's Avatar
That's my plan. No time until Thursday. Just wanted to see if anyone else had any other ideas or something i hadn't thought of. I do have an extra module floating around somewhere and an extra harness just in case. Just sicks because now I have to pull the left cowl piece off.
All sold
2012 XCT,
2003 FLHTCUI
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
