Pinging - What does it sound like? - Victory Forums - Victory Motorcycle Forum
post #1 of 26 (permalink) Old 09-13-2013, 02:05 PM Thread Starter
SilvrT's Avatar
Default Pinging - What does it sound like?
I read a lot of threads here where the term "pinging" is used .... "if it's pinging, then it's too lean"... etc, etc
Now, I know what pinging sounds like in a cage ... "click-click-click" or "ping-ping-ping" real fast. Is this the sound y'all are talkin about? ... -OR- is it more like a "clack-clack-clack" ???
Anyone got a sound clip of what your scoot sounds like when it is pinging?
My bike "clacks" at certain rpms .... is it pinging or is it just valve train "clatter"??
(clickety-clack, clickety-clack, railroad track)
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #2 of 26 (permalink) Old 09-13-2013, 02:33 PM
LILMAGS500's Avatar
Silvr , I get the valve train clackety clack , from 2900 RPM's on up ... Even with no load on my motor the valve train racket is much more pronounced at higher RPM's. Been there since new, I have heard all the 106's have some sort of valve noise in general. I believe when you have excessive pinging , it almost sounds like a jar of marbles rattling around. Kind of like a loud diesel motor running...
LILMAGS500 is offline
post #3 of 26 (permalink) Old 09-13-2013, 02:52 PM
Rebel Biker's Avatar
if it sounds like a jar of marbles rattling around then I'd say it's pinging really really bad. On V8, V6 or even the 4 banger, it may sound like marbles rattling around in a jar because you have 8, 6 or 4 "jars" with a marble in it. In our case we only have 2 "jars." I'd describe it as a jar with A marble bouncing around or a few rocks getting kicked up in the front fender.
You're right...just not quite that bad.
When I was lowering my timing down trying to find the spot where it wouldn't ping, I thought I had it but going up a fairly steep hill and giving it heavy throttle, it pinged but it wasn't bad at all. It sounded like 1 rock got kicked up in the front fender.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #4 of 26 (permalink) Old 09-13-2013, 03:08 PM Thread Starter
SilvrT's Avatar
ahhhhhhh... so the scoot "ping" is much the same as a cage "ping" then and my "clacking" is obviously the valve train.
Gonna start wearing my 3/4 helmet, cranking the tunes, and running loud exhaust so I can't hear it... LOL
What's strange is that some days I hardly notice it and others .... geeeesh ... I'm expecting some internals to blow out the side LOL
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #5 of 26 (permalink) Old 09-13-2013, 03:10 PM
you don't say if your bike is stock or what mods you have done to it.
Never hold back information it will only hurt you. Read my bold print and please do it.
Pinging is a out of the normal sound and it is kinda like a chirping sound. It should only happen under a load like going up a step hill or accelerating hard. You all most never hear it on flat ground at normal cruising.
If you go up a step hill and you think you hear it drop down a gear and if the sound goes away then yes it was pining.
What do you get for gas mileage? If its below 45 mpg then I would say no you don't have pinging.
Go to a dealer and ride a nought bike and compair sounds would be a good deal.
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton vote.
No Tapatalk.
Don't Text and Drive ​​
post #6 of 26 (permalink) Old 09-13-2013, 03:20 PM
It's very likely what you hear is the valves. I think all of us have asked about the noise on our Vics and if it's normal or not because most of us came from something quieter. It is normal and will begin to fade after you put a few thousand miles on it. While I still hear mine, it's no where near as loud after a few oil changes. At first I was a bit embarassed wondering if everybody can hear me clacking.
post #7 of 26 (permalink) Old 09-13-2013, 03:28 PM Thread Starter
SilvrT's Avatar
I've got just under 13,000 kilometers on mine now since I bought it in May 14th with only 3 km.
Just needed to clarify what was "ping" and what was "clack" LOL
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #8 of 26 (permalink) Old 09-13-2013, 03:38 PM
Oh, in that case, your clack is probably going to be the clack from here out.
post #9 of 26 (permalink) Old 09-13-2013, 04:29 PM Thread Starter
SilvrT's Avatar
Will the "real clack" please stand up?
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #10 of 26 (permalink) Old 09-13-2013, 07:41 PM
busajack's Avatar
http://www.contactmagazine.com/Issue...ineBasics.html
Read this and worry some more.
I have to grow old but I don't have to grow UP.thumb up. 2010 Jackpot.
busajack is offline
