Making Side Covers Stay ON! - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 04-21-2014, 03:26 PM Thread Starter
arkiebiker's Avatar
OK...is there anything that can help with making sure the side covers (I have a 2012 XCT) will be "sticky" enough or tight enough not to come out.
Coming back on a 1100 mile trip yesterday (all in 16 hours too I might add)...I come through Memphis...easily the worse roads in the US (yes, that includes YOU Oklahoma)...and hit a bump that jarred my fillings out...or it felt like it and I feel my side cover fall into my leg. Sure enough, the side cover had popped out of the grommet and was leaning against my leg...so I pulled over to the side of the INTERSTATE and POPPED it back in...down the road I go and next bump...OUT pops the side cover again.
So I still need to get the side cover off occasionally, but is there anything to make it "stick" better or make it just SLIGHTLY tighter?
Searcy, AR
Blytheville, AR (Hometown and the BEST BBQ Sandwiches in the world)
Arkansas Bikers Website
http://www.arkansasbiker.net
Garmin Zumo GPS Forums
http://www.zumoforums.com
arkiebiker is online now
post #2 of 13 (permalink) Old 04-21-2014, 03:59 PM
Which side popped off? The wiring harness at the top/left of the left CCT side cover has to held up by the plastic U holder along the lower edge of the tank. If the wiring harness isn't held up high enough, it will not allow the left side cover mounting posts to fully seat into the rubber grommet. There doesn't seem to be as much on the CCT right side cover to make it want to jump off.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is online now
post #3 of 13 (permalink) Old 04-21-2014, 04:05 PM
Judge Redd's Avatar
Make sure all 3 are in. As dumb as that sounds- I have found lining up and properly seating all 3 pegs more difficult than it should be. Can be quite frustrating if not very well lit.
Confirm nothing is broken and that one or more of the rubber seats haven't been knocked loose.
If that's good.. Mcgyver mode...
Maybe the pegs can be thickened up slightly? Just enough to seat more securely, but still actually fit through the grommet (install and remove) without dislocating the rubber seat. My first thought was a couple coats of epoxy that you can brush on kinda like a fingernail color.
(im kinda drugged up on Tylenol sinus)
2014 Judge(Havasu Red) PC-V - ATS(+4) - RPW Boom Sticks - HOHVM1-DR cams - Torque Tubes (dyno sheet) 1/4 turn throttle - OPT7 LED headlight kit - OEM bags, backrest, and W/S
Judge Redd is offline
post #4 of 13 (permalink) Old 04-21-2014, 04:20 PM Thread Starter
arkiebiker's Avatar
Mark...yep. The left side. I put it back on just now and made sure all 3 popped in...but now that you mention Judge Redd....on the side of the road in Memphis, TN AND in a not so nice NEIGHBORHOOD, I wasn't exactly in "leisure" mode.
So lets say that I wasn't in all 3 holes when "under the gun" (forgive the pun)...So I would like the peace of mind (now after 2.5 years of no problems)...of not losing the cover again.
Searcy, AR
post #5 of 13 (permalink) Old 04-21-2014, 04:39 PM
sep1006's Avatar
The right side cover on mine is always loose. Seems like after almost every ride I have to snap the grommet in the top right side back in.
2014 VIC XC PEARL WHITE
STAGE 1 UPGRADE W/K&N FILTER
BLACK TRI-OVAL EXHAUST W/CHROME TIPS
BLACKED OUT LENS'
LOWERING LINK ( DROPPED 2" )
CUSTOM PINSTRIPING
PAINTED OUTER CHIN SPOILERS
GUSTAFSON EUROFLIP +2"[/B]
RICZ LAYDOWN PLATE
DEBADGED AND REFLECTORS REMOVED
O2 SENSORS DISCONNECTED
LLOYDS TIMING WHEEL
SHORTY ANTENNA FROM MINI-COOPER
21"WHEEL KIT FROM WD
BUNCH OF NESS ADD-ONS
sep1006 is offline
post #6 of 13 (permalink) Old 06-02-2014, 07:50 PM
Don
Don's Avatar
I have the same problem with my 12 Cross Roads Classic. Two days ago driving down highway and left side come off. Caught it before it completely left the bike. Both sides come off way to easily. Seems to me the hole in grommet is just too big. I'm wondering if a little tape or something around pegs of panel would work? I need to do something because I can just image what a new panel would cost!!!!!
2012 Cross Roads Classic LE #247
London Ont. Canada
Sage Brush Tank Bib, Utopia Driver Back Rest, Victory Tach, Lloydz Timing Wheel, Lloydz 1/4 Turn Throttle, Victory High Flow Filter, RC 4" Slipon Exhaust, Power Commander 5, Victory passenger Floorboard
06 VTX 1300R(sold)
08 Suzuki C50(sold)
Don is offline
post #7 of 13 (permalink) Old 06-02-2014, 11:17 PM
About 3 years back, my side covers were too loose in the grommets and my dealer ordered 6 replacements. They were a lot tighter and I have had no problem since. Get yourselves a set--that seems to be the cure. Dunno why the replacements would be better than the originals, but they are.
2010 Midnight Cherry XR. 7Jurock, Lloydz AF, ATS, VFCIII, IAV, and T-6 and locally repacked pipes = big smiles.
+ For the best and cheapest Cross bike license plate laydown bracket, click this:http://www.victoryforums.com/showthr...=riczsifieds/+
RICZ is online now
post #8 of 13 (permalink) Old 06-03-2014, 12:37 AM
Get some big heat shrink tubing and put on the studs on the cover to make 'email more snug. May take more than one layer--mine didn't.
2012 XCT White
San Antonio, TX
Honda CB350, Penton 125, Penton 175, Honda MR 175, Honda TL250, Yamaha IT 175, Husky 250CR, Husky 360 Auto, Husky 390WR, BMW R90/6, Honda CX 500, 84 Goldwing, 93 Goldwing, 98 Goldwing, 2012 Victory XCT
thumbgone is offline
post #9 of 13 (permalink) Old 06-03-2014, 01:53 AM
Just get new grommets.....cheap compared to replacing a side cover.
Ive never had trouble with mine.....then again I dont remove them often - maybe twice since I owned the bike.
I really wish they wouldnt have put the air connector under there - thats the only real reason to remove it.
aaronrkelly is offline
post #10 of 13 (permalink) Old 06-03-2014, 07:20 AM
Pop
Good input. 1st choice new grommets. Heat shrink in the meantime or as a fix. I put spray tack on mine. They never have been a problem but I just didn't trust them. I have to work a little to get them off but that's what I was going for.
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
