Shifting Issue - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 06-19-2012, 03:17 PM Thread Starter
Default Shifting Issue
I have an '05 Vegas Kingpin that, on occasion, has trouble shifting up between 2nd and 3rd gear. When I go to shift gears between 2nd and 3rd, it will "stick" and not shift into third gear. If I try a second time right after this happens, it will shift fine. This is the only scenario where this "sticking" occurs.
I just bought the bike a couple of weeks ago. I did some searching on the forums and I've heard folks talk about "lubricating the heim joints" or "replacing the ratchet shifter" to potentially solve this problem. I'm somewhat mechanically inclined but don't have a service manual and wouldn't even know where to start to do either of these things...
So, would performing either of the above tasks solve this issue ? If not, what other things could be causing this, and how would I fix it ?
Thanks !!
kjzeusman is offline
post #2 of 7 (permalink) Old 06-19-2012, 03:23 PM
Your clutch might be out of adjust men and you can only adjust it when its over night COLD not some what cold.
Do a search here for a manual you can down load.
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton vote.
No Tapatalk.
Don't Text and Drive ​​
post #3 of 7 (permalink) Old 06-19-2012, 03:52 PM Thread Starter
Wouldn't a misaligned clutch exhibit the shifting behavior on all gears though, not just one gear (and in one direction only) ?
post #4 of 7 (permalink) Old 06-19-2012, 05:06 PM
gibson's Avatar
bent shift fork, worn gear shift ratchet mechanism,bent or distorted shift fork rails,debris from broken parts locking transmission,chipped or broken teeth, best thing to do is open it up and inspect for damage.
2012 Fireball Jackpot
gibson is offline
post #5 of 7 (permalink) Old 06-19-2012, 05:17 PM
kevinx's Avatar
No, maybe, no, no, no, no, and absolutely not.
First thing to do is to remove the rod that goes from the shifter to the trans, clean and lubricate the balls at each end, and see where that gets you. If that does not solve your problem. Replace your shift ratchet assembly
kevinx is offline
post #6 of 7 (permalink) Old 06-19-2012, 05:52 PM Thread Starter
KevinX, thank you again - very much appreciate your help Will give this a try.
If I end up having to replace the shift ratchet assembly, how difficult is that to do ? Is that something someone could do on their own or is it a "don't mess with this - leave it to an expert" scenario ?
post #7 of 7 (permalink) Old 11-03-2012, 02:38 PM
saintdruss13's Avatar
Hey kjzeusman did you get the issue solved?
My 04 TC is doing what I think is the same thing but as I'm building up RPM's in 2nd I can actually feel the shifter lifting on its own a little then I can't shift in to 3rd. It only dose it if I'm really getting after it.
Captain Spalding's Fried chicken and gasoline. * EXIT 13 OFF ROUT 1 at RUGGSVILLE*
2004 TC, 05 Vegas 8Ball, 09 Yamaha FZ6R
Lake Havasu City AZ.
saintdruss13 is offline
