Why is the dagblastit gear changes so noisey? - Victory Forums - Victory Motorcycle Forum
post #1 of 44 (permalink) Old 06-25-2012, 03:10 AM Thread Starter
ddharris's Avatar
Default Why is the dagblastit gear changes so noisey?
I want to take off the transmission cover and find the monkey with the ballpein hammer! Are victory transmission that much nosier than a Hardely? Any thing can be done? Good lawd.
2013 Sunset Red Judge
2011 Silver Aprilia Shiver 750
ddharris is offline
post #2 of 44 (permalink) Old 06-25-2012, 07:02 AM
navycraig's Avatar
Mine got better after the first service at 500 miles. It got better again when I had a need to change the oil (don't ask) about a hundred miles later and I switched over to Amsoil. It seems to soften up over time and now with 1600 on the bike it's not near as bad as it was in the beginning.
God Bless America
U.S. Navy Retired
2012 Victory Crossroads Classic L.E. (#258)
PC V and Dyno tuned by Kyle of KMC
Lloydz High Flow Filter
Lloydz Timing Wheel
Lloydz Drop In Cams
Lloydz 1/4 Turn Throttle
Crossroads HID high/low lights
Making 113 HP and 115 TQ
navycraig is offline
post #3 of 44 (permalink) Old 06-25-2012, 08:38 AM
depot picker's Avatar
Smile
With 21,000 I don't know if it is still noisy or not, but I don't notice anymore.
IBA Member
2012 XCT "Marguerite" 111/107
PCV, timing wheel, DR cams and tuned
Lloydz filter, drilled, Ness modular apes.
depot picker is offline
post #4 of 44 (permalink) Old 06-25-2012, 09:03 AM
handyhoward's Avatar
Hardly motorcycles have had their share of noise issues with their trans... they however can be quieted down considerably by using gear lube... a choice that the Victories do not have.
Victory trans are especially noisy when they are being shifted at to low rpm's... they are designed to be shifted and run at higher rpm's... try it out. They can't be lugged out at low rpm's... the monkey gets angry.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #5 of 44 (permalink) Old 06-25-2012, 09:17 AM
Mine has over 5k on it, and it's the same as when I got it. Just changed the oil and it does shift a little better.
That being said, I rode a 2011 Electra Glide with similar mileage two weekends ago, and that thing shifted 100 time better than my CR.
zilla is offline
post #6 of 44 (permalink) Old 06-25-2012, 10:09 AM
I don't know which oil works the creamiest in the Vic., But I would think a good 20W50 semi-synthetic or a conventional oil would provide the most cushion. I however tried royal purple in mine after the 500 mi break-in and shifting has improved quit a bit.
2012 Vision Tour
Oklahoma City, Ok.
atom bomb mod
ATS +4
A-dog is offline
post #7 of 44 (permalink) Old 06-25-2012, 11:01 AM
Run it up around 3500 and then shift. Its a huge difference if your short shifting and lugging it they are really noisey. 1st to 2nd on mine is fine when i shift below 3500 but after that its much smoother in the 3000-3500 range. Also im running amsoil and seems to help alot. Also make sure your clutch is adjusted right and has the freeplay it needs or once it heats up the cable can be tight enough to cause rough shifting as well.
2006 Extreme vegas Jackpot
S&S intake
05 hammer drag map
RPW Swept pipes
2013 red blacked out cross country
High, low HID kit
Ness grips
Ness Rad III mirrors
Noemtz Thunder Monster exhaust
Lloydz air filter
VM1 Cams done by Rylan @ The Vic Shop
lloydz timing wheel
Trvshonda is offline
post #8 of 44 (permalink) Old 06-25-2012, 01:05 PM
Azdave's Avatar
Sort of like the trans from the muscle cars. I had a 67 Camaro SS with a Rock Crusher trans in it. Now that was a noise maker. Shift it like it was meant to be ridden and no worries.
Blame it on me
2014 HD Street Glide
2013 Vision Sunset Red
2006 Jackpot sold
2006 Vrod Screaming Eagle (sold)
1972 Kawasaki 1000
Azdave is offline
post #9 of 44 (permalink) Old 06-25-2012, 01:38 PM
You can have quiet and it breaks or louder and it lasts forever. I prefer louder and lasts forever.
WilCon76 is offline
post #10 of 44 (permalink) Old 06-25-2012, 01:42 PM Thread Starter
ddharris's Avatar
I am running amsoil and I agree with the higher RPM shifting. It is very quiet once you get going. But low speed you get a nice audible "Clack". I engauge at a red light and look around to see if anyone is looking at me.
I just have to get used to it.
ddharris is offline
