High Idle when engine gets hot.... 1400-1500 rpms. - Page 4 - Victory Forums - Victory Motorcycle Forum
 1Likes
post #31 of 43 (permalink) Old 11-19-2012, 08:36 PM Thread Starter
Marius's Avatar
Originally Posted by CrossRoads View Post
Actually, the original part number seems to be: 1253335 (and was used on 02-06 models) which was subtituted by 1203277 for all 2007 models.
Did you try these guys: http://www.gearhead.com/1203277.html#/s/POL//1203277/1 ?
Also, try contacting these folks and see if they have it in stock: http://www.speedsupplies.com/parts/polaris-1203277.htm.
Haven't tried either of those yet, I'll call them both in the morning, thanks a bunch!
2007 Victory Hammer (Nuclear Sunset)
2012 Vstrom Adventure 650
2006 Suzuki M50 (Black) - Traded
1995 Mustang GT... Work in Progress...
Marius is offline
post #32 of 43 (permalink) Old 11-20-2012, 10:51 AM
1203277 is the part number for throttle body adapter on the pure polaris parts cat but when you do s search on that part on the net all places say its discontinued?
hammer316 is offline
post #33 of 43 (permalink) Old 11-20-2012, 11:22 AM Thread Starter
Marius's Avatar
When i call the parts retailers they tell me their systems show that 1203277 part is discontinued and they can no longer get it. Polaris on the other hand says its not discontinued, but it is on a backorder without an estimated availability date.
Marius is offline
post #34 of 43 (permalink) Old 11-20-2012, 11:39 AM
i am finding getting parts for these motorcycle is no joy the dealers dont stock anything of if they have to order anything its always backorder.Since there seems to be a problem with these throttle body adapters you would think they would have a good stock of them or fix the problem with them.My dealer didnt even have exhaust gaskets in stock.I understand that service all different kinds of vehicles but they should atleast have some stock.I think exhaust gaskets are a common part that gets changed alot people are always changing their pipes.Good luck on getting that throttle body adapter
post #35 of 43 (permalink) Old 11-20-2012, 04:32 PM
called vic dealer gave him part number 1203277 he says no longer avalible its a throttle body adapter you have to be able to get it.I also have a black gasket that sits on top of the throttle body inbetween the air box and throttle body and that does not show in the parts break down.He is going to call polaris but not to impressed with trying to get parts for this bike
post #36 of 43 (permalink) Old 11-20-2012, 05:25 PM Thread Starter
Marius's Avatar
When you cant get parts for an American bike, in America... somebody is screwing the pooch!
C'mon Victory/Polaris!!!
Marius is offline
post #37 of 43 (permalink) Old 11-21-2012, 12:14 AM
Dealer said part is unavialable what ever that means they were suppose to call vic and find out whats going with that part.They didnt call back this afternoon go figure lol.If i hear back from them and get some info i will pass it along but alot of other sites tha thave parts look up shows that part but does not list it so there is some king of problem getting it
post #38 of 43 (permalink) Old 03-24-2013, 08:37 PM Thread Starter
Marius's Avatar
Hurray for me! I got the parts and finally found the time to take care of this problem. I spent the better part of the weekend replacing the throttle body adapter. I wasn't in a rush, it seemed intimidating at first, but turned out not to be, probably because I had all the right tools.
One thing for anyone who might have to do this in the future: the manual says you'll pull the throttle body out through the right side of the bike. My arse! There's no way in hell, don't even try. The fuel rail is in the way and it's just too tight. I pulled it out through the back though, only had to unhook the thick wiring harness from the rail to make some extra room. Easy peasy.
The old throttle body adapter looked real rotten out and was cracked where the top cap met the cylinder. Funny thing is, my high idle issue probably had to do with the idle screw adjustment, which I didn't realize these bikes had until I got to working on it. Now Purs like a kitten at 1000 rpms at idle and I'm a happy camper!
Hot dang this thing pulls hard without any vacuum leaks! WOOOOOT!
Marius is offline
post #39 of 43 (permalink) Old 03-24-2013, 08:49 PM Thread Starter
Marius's Avatar
The bike has 2500 miles now, so I was stunned to see this much carbon and sut build up here. This probably had to do with the vacuum leak and most likely bad gas , since the previous owner didn't ride it much and didn't use fuel stabilizer in the tank.
Marius is offline
post #40 of 43 (permalink) Old 03-24-2013, 08:52 PM Thread Starter
Marius's Avatar
Squeeky clean one on the left. Cleaned them both to look like new before i installed the new adapter. No more leaks!
Marius is offline
