Turn signal load resistance - Page 2 - Victory Forums - Victory Motorcycle Forum
post #11 of 14 (permalink) Old 11-13-2012, 11:19 AM
CrossRoads's Avatar
Originally Posted by Gunslinger View Post
Wow... poor advice all around.
Really? I think telling someone to tape wires together with electrical tape, on a motorcycle is as poor advice as one could give.
Originally Posted by clicker666 View Post
... The seller said to put them parallel in the circuit. ...
Parallel is correct. Connect the resistor parallel to the two wires from the LED turn signal lights using T-Tap.
black wire on harness ----- black wire on resistor -----black wire on signal--
blue wire on signal ---- white wire on resistor ---- blue wire on harness.
Yes, that's the right way.
CrossRoads is offline
post #12 of 14 (permalink) Old 11-13-2012, 12:31 PM
Yup, shameful! This is MBW's Load Equalizer for Victory..
http://www.mbwmotorcycle.com/products/Vegas.html
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
post #13 of 14 (permalink) Old 11-13-2012, 12:33 PM
clicker666's Avatar
So MBW's splices the two yellow wires to the positive leads of the rear taillights, and the black wire goes to ground?
2006 Victory Vegas 8-Ball
"A man who wants to do something will find a way; a man who doesn't will find an excuse." Stephen Dooley, Jr.
clicker666 is offline
post #14 of 14 (permalink) Old 11-13-2012, 12:45 PM
Well, yes, and no.... no splicing (which implies a cut). They are tapped onto the left and right positive signal wires. Because the the front left and rear left are in series, the load will be drawn per side, not just front or back.
