Turn signal load resistance - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 10-13-2012, 12:16 AM Thread Starter
Default Turn signal load resistance
High all, I just installed an LED rear blinker system on my 2012 high ball. I know that people sell load equalizers for $30+ and I know that all it is, is a resistor which I could get at radio shack for a buck. My question is, does anyone know what Ohm resistors to get?
Sent from my iPad
cdickgo is offline
post #2 of 14 (permalink) Old 10-16-2012, 07:16 PM Thread Starter
Anyone? Surely someone must have tried this?
Sent from my iPad
cdickgo is offline
post #3 of 14 (permalink) Old 10-16-2012, 07:20 PM
CrossRoads's Avatar
There is a reason why the load equalizers are the better way to go, even though they cost more. Resistors will put out significant heat, which can likely melt any plastic they will come in contact with, including any wire insulation they might touch or come close enough to.
That being said, if you're still willing to save money and go the resistor way, I would suggest an 8ohm, 20 or 25 watt resistor for each side.
CrossRoads is offline
post #4 of 14 (permalink) Old 10-17-2012, 04:07 AM
gibson's Avatar
http://www.matstrad.com/resistors_tech.php
gibson is offline
post #5 of 14 (permalink) Old 10-17-2012, 09:33 AM
clicker666's Avatar
I purchased a set of these, do you think they will be too hot or will the sinks on them dissipate well enough?
2006 Victory Vegas 8-Ball
"A man who wants to do something will find a way; a man who doesn't will find an excuse." Stephen Dooley, Jr.
clicker666 is offline
post #6 of 14 (permalink) Old 10-17-2012, 10:28 AM
CrossRoads's Avatar
Just mount them somewhere where they're aired well (not buried in the headlight bucket, or some other nook) and check on them to see how hot they get to the touch.
post #7 of 14 (permalink) Old 10-17-2012, 10:32 AM
clicker666's Avatar
I'm going to use them with the tails. I imagine there should be a place there to put them. Still waiting on the actual tails, so I haven't done anything yet.
post #8 of 14 (permalink) Old 10-17-2012, 01:00 PM
atomicdog's Avatar
Their rated to handle over twice as many watts then what could be used in this application. A little air flow should keep them cool enough.
12 volts / 6 Ohms = 2 amps
2 amps x 12v = 24 watts
Those resisters are rated for 50 watts.
2012 Vegas 8-ball
atomicdog is offline
post #9 of 14 (permalink) Old 11-13-2012, 11:43 AM
clicker666's Avatar
I test fitted these with the new flush led turn signals the other day. The signals flash fast without. The seller said to put them parallel in the circuit. Installed this way the light flashes once, then doesn't flash again. Reversing the wiring produces no flash. I'm kind of wondering why they're not in series with either the positive or negative side of the light. So:
black wire on harness ----- black wire on resistor -----black wire on signal--
blue wire on signal ---- white wire on resistor ---- blue wire on harness.
or
black wire on harness ---- entire resistor --- light --- back to blue wire on harness
or
black wire on harness ----light--- entire resistor --- back to blue wire on harness
post #10 of 14 (permalink) Old 11-13-2012, 11:57 AM
Wow... poor advice all around.
Get a pair of these http://www.radioshack.com/product/in...ductId=2062288 for all four turn signals replaced with LEDs
Or a pair of 10watt 10ohm may work for just front or rears replaced with LEDs
You can tape them together with electrical tape or heat shrink, and twist together two of the ends into a single wound lead, and TAP or attach to ground. Take each of the two free leads and TAP (not splice) to each left and right blinker circuits. Left is the blue, and right is the blue with red stripe. They do NOT run in parallel with each blinker! They handle the entire left and right side of the bike, front to back! The best place to put them is under the seat. Find the wiring harness leading OUT of the ACM (auto cancel module) and locate the aforementioned left/right leads.... it's really pretty simple.
There are TONS of threads on this on other sites....
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
