Oil cooler line question - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 10-18-2012, 06:54 PM Thread Starter
Default Oil cooler line question
I have a 2012 Hammer S. Have the 2012 shop manual.
According to the shop manual, the LOWER hose on the oil cooler (also the INNER hose on the left side of the engine) takes HOT oil from the engine to the oil cooler.
Also, the UPPER hose on the cooler (also the OUTER hose on the left side of the engine) takes COOL oil from the cooler and returns it to the engine.
HOWEVER, on the Victory Parts Fische the LOWER hose is described as "engine in". This seems to contradict the shop manual. To me "engine in" means from cooler to engine. While manual states engine to cooler.
UPPER hose in fische described as "engine out". Again seems to contradict manual. "Engine out" to me means from engine to cooler.
MY QUESTION: based on actual experience, which oil hose, UPPER or LOWER, takes HOT engine oil to the cooler? i.e. which source is correct: shop manual or fische? Again Freedom 106 engine.
THX
KROWBAR is offline
post #2 of 10 (permalink) Old 10-18-2012, 08:51 PM
depot picker's Avatar
See which hose gets hotter.
IBA Member
2012 XCT "Marguerite" 111/107
PCV, timing wheel, DR cams and tuned
Lloydz filter, drilled, Ness modular apes.
depot picker is online now
post #3 of 10 (permalink) Old 10-19-2012, 06:06 AM
gibson's Avatar
comes from oil pump lower hose to oil cooler to upper hose crank case passage to cylinder heads. 4.4 in the book. So it is opposite of a water radiator of old.
gibson is offline
post #4 of 10 (permalink) Old 10-25-2012, 08:03 PM
lunaticrider's Avatar
In my experience the service manual is correct, I had a similar conflicting issue with kawasaki and they said the service manual is always correct...
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #5 of 10 (permalink) Old 10-25-2012, 10:51 PM Thread Starter
THX for the answers all.
KROWBAR is offline
post #6 of 10 (permalink) Old 12-16-2012, 09:34 PM Thread Starter
Finally got a chance to test the oil lines. The outer/upper line takes oil FROM the engine and sends it TO the cooler. The inner/lower line is the return line.
Parts fiche is correct, shop manual is wrong. At least for a 2012 Hammer S.
KROWBAR is offline
post #7 of 10 (permalink) Old 12-17-2012, 01:10 PM
Why do you want to know?
What are you going to do?
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton vote.
No Tapatalk.
Don't Text and Drive ​​
post #8 of 10 (permalink) Old 12-17-2012, 06:09 PM Thread Starter
Put in an oil temp sensor (tee into outside line). Wanted to know if I was getting hot oil from engine, or cooler oil from the oil cooler. I'm a little crazy about knowing how things work on my bike. Also don't get the warm fuzzies when a shop manual is wrong. What else is wrong?
KROWBAR is offline
post #9 of 10 (permalink) Old 12-18-2012, 02:15 PM
Why not put a T in where the oil sensor goes into the motor. You'll still get temp and it will be cleaner and easier.
Keep in mind the oil lines are under pressure so if your off a littler you will have a leak.
No Tapatalk.
post #10 of 10 (permalink) Old 12-18-2012, 06:09 PM Thread Starter
Tee'ing the oil pressure orafice for an oil pressure gauge, plus better oil flow (more accurate reading) by teeing into oil line.
You are right have to watch for leaks. The "fabric covered" part of the line is thin plastic 5/16" ID pipe with a fabric cover. Wish it was rubber. I bought a spare line in case things don't work out.
KROWBAR is offline
