Battery - Replacement - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 11-05-2012, 08:11 AM Thread Starter
Roughrider's Avatar
Good Morning,
One important question?
Cross Country calls for a battery with 310 Cold Cranking Amps.
Is it safe to go with a higher cca battery?
Any and all advise will be appreciated.
Stay Safe and Live long,
Roughrider
2011 Cross Country
Roughrider is offline
post #2 of 21 (permalink) Old 11-05-2012, 08:29 AM
i like to go with a little higher cca. if you go to a higher compression or add cams sometimes you have to go higher. no need to get crazy if you aren't bumping up compression though, or maybe start it in very cold weather a lot. personally i would go with about a 350cca on a stock compression/cam bike.
now , 2011 crossroads and 05 sportster bobber in the making
in order of ownership, sears compact scooter, honda 305 scrambler, honda 160 dream , triumph 500 trophy trail, honda cb450, sportster, honda f750, 2nd sportster, harley flh, harley super glide, 3rd sportster, bmw k1000, harley low rider, 2nd harley super glide, harley heratage, harley road king, bmw r1150rt,
thats just the street bikes!
ridealittle is offline
post #3 of 21 (permalink) Old 11-05-2012, 09:16 AM Thread Starter
Roughrider's Avatar
Battery
Thinking of purchasing the following:
MagnaPower 12-Volt Sealed AGM Premium Powersport Battery, 440 CCA.Do you think this is over kill?
Or should I just stick with the following:
MagnaPower 12-Volt Sealed AGM Premium Powersport Battery, 310 CCA.
Currently use the 310 CCa on my Yamaha Road Star, very god battery.
Number one priority is to not to damage anything on my Cross Country if I go with a higher CCA battery!
Roughrider
2011 Cross Country
post #4 of 21 (permalink) Old 11-05-2012, 10:08 AM
Dont think you will damange anything with the 440 cca battery If its only a few bucks more And it fits in place well Why not
2006 kingpin
S&S Intake
Hard Krome 3in big straights
Ness Ram bars
tfkp is offline
post #5 of 21 (permalink) Old 11-05-2012, 11:46 AM
Good thinking on your part "but" why? Your bike is only a 2011 and you should get another 5 years out of it. You want to spend $135 bucks.
The stock battery is very good and will give you a lot of life.
The only poor part about victory is the cables come loose quite often. You can fix that with some star washer you can buy at any hardware store. You want a 1/4" size.
Heck my 08 vision still has the stock battery in it.
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton vote.
No Tapatalk.
​DO NOT TEXT AND DRIVE
post #6 of 21 (permalink) Old 11-05-2012, 01:40 PM
gibson's Avatar
I bet you keep yours in the living room in the winter..
2012 Fireball Jackpot
gibson is offline
post #7 of 21 (permalink) Old 11-05-2012, 05:10 PM
in my experience, the higher the cca, the better made and longer lasting the battery is. usually a lot heavier with more lead. the 440 will start a car but if thats what you want i would get it.
post #8 of 21 (permalink) Old 11-06-2012, 07:40 AM Thread Starter
Roughrider's Avatar
Up-date
Had to go with the Extreme Magna Power 310 CCA.
The 440 CCA was a little to large.
Put star washers when I brought XC home for the first time. Good advise!
Thank you all for your assistance in this matter!
Roughrider
2011 Cross Country
post #9 of 21 (permalink) Old 11-06-2012, 11:10 AM
43 Degrees out rode to vote and then up to the city's. 72 miles today.
Why would you be looking for a battery when the bike is only a year old. Bigger battery more horse power and now a 1000 w amp
No Tapatalk.
post #10 of 21 (permalink) Old 03-27-2013, 02:38 PM
depot picker's Avatar
Ive cleaned the battery cables to obsession, bent the pins some on the regulator connector per Kevinx, and it still doesn't crank for crap on a cold morning. At 1.5 years, I'm thinking the battery is a PoS.
IBA Member
2012 XCT "Marguerite" 111/107
PCV, timing wheel, DR cams and tuned
Lloydz filter, drilled, Ness modular apes.
depot picker is offline
