Belt Tension Specs Too Tight? - Page 2 - Victory Forums - Victory Motorcycle Forum
post #11 of 15 (permalink) Old 11-14-2012, 10:12 AM
dtmmil's Avatar
How many of you use the tension tool? I have not used one yet, thinking of getting one though.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #12 of 15 (permalink) Old 11-14-2012, 10:50 AM
TNXR's Avatar
I bought one a few weeks ago to adjust my belt for my 500 mile service. Easy to use but I do suggest taping the ruler to a small box or something so that it will not move. I had a tough time trying to hold the ruler and do the deflection measurment and getting a good reading every time. You can get them on Amazon for $25 or so. I would also suggest getting a 27mm crowsfoot so you can torque your axle bolt to specs without having to remove the muffler.
2011 Cross Roads Sunset Red
OEM short windshield, passenger backrest, crash bars, saddle bag bars, heated grips, vinyl closeouts, tachometer, ambient temp. WD lay down licence plate.
TNXR is offline
post #13 of 15 (permalink) Old 11-14-2012, 12:03 PM Thread Starter
I have one from Harley that I've had for years. I've checked my belts on my Harley and Victory's for years, so I can pretty much put 10 lbs of pressure on the belt without using the gauge. But, since the spec is so small, 5 to 6 mm, I used the gauge on this one. I also have these paper rulers I got from IKEA and just cut off part of those rulers and tape them on the belt guard to meassure the deflection. It's a lot easier than trying to hold a ruler and a belt tension gauge and push up on the belt.
jcanrun is offline
post #14 of 15 (permalink) Old 11-14-2012, 03:22 PM
dtmmil's Avatar
Thanks, i saw one on ebay for $22 shipped, and my deflection is suppose to be a little over an inch, I think its 32mm with the tire off the ground, and yes I have a 27mm crowsfoot, very well worth it!
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #15 of 15 (permalink) Old 11-14-2012, 05:28 PM
TNXR's Avatar
You probably already know but your lb pounds of torque will be a little less with the crowsfoot. For my torque wrench it was about 57 lbs (compared to the 65 lbs in the manual).
TNXR is offline
