Belt Tension Specs Too Tight? - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 11-13-2012, 02:13 PM Thread Starter
Default Belt Tension Specs Too Tight?
Just an observation. For my 13 Boardwalk (and for the Vegas 8 ball, vegas jackpot, hammer 8 ball, highball, and judge) the belt deflection spec is 5 mm +/- 0.5 mm or 6 mm +/- 0.5 mm over 600 miles on the bike. That's 1/2 of a centimeter. That seems a little tight for my tastes. Plus, how the heck does 0.5 mm even show up on a ruler when you are measuring defection. 1/2 of a millimeter is suppose to be visible on ruler?
Anyways, this seems pretty tight to me cause I did adjust my belt to about 5 mm or a little more while the tire off the ground at the tightest spot in the belt. When the tires on the ground, it barely has any deflection. I can't imagine when the bike is hot (pulleys expand causing belt to tighten even further) or when the suspension fully compresses (belt is tight as possible).
Just wondering what everyone's thoughts are on this.
jcanrun is offline
post #2 of 15 (permalink) Old 11-13-2012, 03:02 PM
half_crazy's Avatar
My service manual says 12mm +/- .5mm (about 1/2") after 500 miles.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #3 of 15 (permalink) Old 11-13-2012, 03:23 PM Thread Starter
Ya, the Hammer S has specs of 10 mm +/- 0.5 mm or 12 mm +/- .5 mm after 500 miles. I think it has to do with the low suspension on my bike and others incluing the Kingpin low. Still 5mm is pretty tight.
jcanrun is offline
post #4 of 15 (permalink) Old 11-13-2012, 04:08 PM
6 mm is 1/4 inch. My gauge is easily able to measure that.
lcoblentz3 is offline
post #5 of 15 (permalink) Old 11-13-2012, 04:34 PM
Not trying to rain on ya parade but Victory engineers know a hell of a lot about their final drive systems.
Make sure your ride height is set to spec first. With you sitting on bike.
Right side adjusts tension, left side adjusts belt alignment on rear pulley.... as you know.
Can be a bit of a juggling act to get right tension and alignment.
Check tension in 4 places... or find tightest area as you have said.
Mags
2012 Jackpot.
Mags is offline
post #6 of 15 (permalink) Old 11-13-2012, 07:09 PM
TNXR's Avatar
Both adjusters have to be used to adjust tension, not just the right side. The left side is used to align the belt as not to mess with deflection very much.
2011 Cross Roads Sunset Red
OEM short windshield, passenger backrest, crash bars, saddle bag bars, heated grips, vinyl closeouts, tachometer, ambient temp. WD lay down licence plate.
TNXR is offline
post #7 of 15 (permalink) Old 11-13-2012, 07:18 PM
half_crazy's Avatar
My bike is not a "low"...
post #8 of 15 (permalink) Old 11-13-2012, 07:53 PM Thread Starter
exactly, i think that's why your spec is 10 mm / 12 mm.
jcanrun is offline
post #9 of 15 (permalink) Old 11-13-2012, 09:15 PM
Kingpin spec is different than vegas. Not sure of the boardwalk, but I suspect your manual is correct. 6mm isn't that difficult to measure.....
post #10 of 15 (permalink) Old 11-14-2012, 01:02 AM
robvision's Avatar
I mentioned this before -
Adjusting the belt when the bike is cold is just crazy
My belt has at least 2 inches of deflection when cold. Thats 2.5cm per inch or 25mm for a total of 50mm and after a short ride when the pulleys warm up the belt is snug..... With the use of all the aluminium there is a huge amount of expansion going on.
So I adjusted mine after a ride. It just makes sense.
When I adjusted mine cold at 12mm - after a short ride it was so tight you could use it to play a tune.
Leaving it this tight will destroy the bearings in the wheel or the tranny pulley shaft bearings.
I have my belt running in the middle of the pulley. It wanders around from side to side but for the most part does NOT touch the sides of the rear pulley.
When the bike is cold the belt is VERY loose and after a short ride it is semi snug.
These belts do not need to be real tight......
Rob
[SIGPIC]
Rob
2010 V Star 650 Custom (Wife's)
2013 XCT 2013 Suzuki KQ750 AXI Power Steerring
Victory Sport Touring Flag Ship
Lloydz Idle Air Valve
Lloydz PTW
60,000 km
Rear Rack
Passenger Grab Handles
Modified Heel Shifter
HID Low
Oil Temp Gauge
Ride-On TPS
Modified Stock Pipes by Thrush
K&N air filter
G-man Bully FI Controller
Heat Troller
LED Driving lights
PCV with AutoTune
robvision is offline
