Anyone Have Problems With Loydz Air Filter - Page 2 - Victory Forums - Victory Motorcycle Forum
post #11 of 13 (permalink) Old 11-17-2012, 05:49 AM
saddlebag's Avatar
Originally Posted by ndabunka View Post
Not certain of the cause of your concern. The filters COMPLETELY SEALS off the intake with, well.... the filter itself. If any water DID happen to get "too" the filter, the filter would simply absorb it, right?
If it's the oil type, I would imagine the oil would prevent most of the water from entering the filter to begin with. I'd think it would bead up and run off it unless applied at high pressure.
http://www.victoryforums.com/signaturepics/sigpic6903_1.gif
2011 Cross Roads
saddlebag is offline
post #12 of 13 (permalink) Old 11-17-2012, 07:11 AM
Pop
Engines are tolerant of rain. Rain infiltration is an expected design consideration so failure from rainwater is not likely. Water is channeled away, engine heat evaporates water, the filter atomizes it, and under pressure it converts to hydrogen and oxygen. In the right circumstances, it could even increase hp and decrease heat. Not a recommendation, just a hypothetical.
I had an Evo parked in a basement garage at our beach place when floods came. Found the bikes by wading chestdeep through beach balls and floating coolers until we caught the glint off my buddy's streetside mirror on his apehangers about an inch out of the water.
Rolled the bikes up to high ground and pulled the plugs. Toweled off the battery connections as best we could in the pouring rain and hit the button. Spewed a stream of mist for a few revs. Dumped some Marvel down the plug holes and tarped them. Waited for two days until the roads were open to take my bike to the dealer. It was only a month old after all.
Fluid changes, a couple of handlebar switches and I was good to go three days later.
When I picked up the bike the wrench said that it was 99% dry. I pushed the button and it fired right up. I threw a leg over it and when I sat down I found out what the wet 1% was.
Still own that bike 16 years later and have never been in the motor or had electrical problem one (that I didn't bring on myself).
Red.
2012
Cross Country Tour.
We can't help it
We just keep moving
It's been that way since long ago
Since the stone age chasing the great herds
We mostly go where we have to go
That was written by James McMurtry
Pop is offline
post #13 of 13 (permalink) Old 11-17-2012, 12:11 PM
BThomas's Avatar
Great info Pop! I didnt realize how high a tolerance bikes had for h2o. Thanks for sharing that!
Sent from my iPhone using Motorcycle.com Free App
2012 Cross Country--trunk at times, stereo/amp upgrade, Madstad Windshield bracket, old-man style heated seat/grips, RPW Exhaust/Lloydz ATS and filter, PCV/AT, Cycleops Cheese, side covers and primary insert, soft lowers, a bit of chrome...
BThomas is offline
