leaking shifter seal - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 11-16-2012, 09:20 PM Thread Starter
depot picker's Avatar
Default leaking shifter seal
After a 220 mile ride today I left her parked for a few minutes while unloading before going grocery shopping. When I came out there was a puddle of oil below the shifter shaft. The seal looked like it was sticking out a bit, so I stuffed it back into the case with a screw driver. This stopped the drip.
I'm sure this isn't a permanent fix, but I won't be home to look at my service manual until Sunday. I'm wondering what it is that should hold the seal in place. Is it just a pressed fit?
IBA Member
2012 XCT "Marguerite" 111/107
PCV, timing wheel, DR cams and tuned
Lloydz filter, drilled, Ness modular apes.
depot picker is offline
post #2 of 19 (permalink) Old 11-16-2012, 10:42 PM
Can you identify it in this picture?
post #3 of 19 (permalink) Old 11-16-2012, 10:46 PM
Or maybe in this one...
post #4 of 19 (permalink) Old 11-17-2012, 07:54 AM
gibson's Avatar
[ATTACH]Attachment 8815[/ATTACH] here is your answer..
2012 Fireball Jackpot
gibson is offline
post #5 of 19 (permalink) Old 11-17-2012, 08:17 AM Thread Starter
Thanks guys. I can't find it in BBob's, but Gibson's picture has it.
IBA Member
post #6 of 19 (permalink) Old 11-17-2012, 09:35 AM
Edit: It's number 3 in the lower pic I posted but gibson's is much better for sure.
post #7 of 19 (permalink) Old 11-17-2012, 11:51 AM
If you could push it back in have dealer order you a new one. It must be a tad small for the opening. The seal is a press fit
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton
No Polaris ever again
Don't Text and Drive
post #8 of 19 (permalink) Old 11-17-2012, 01:46 PM Thread Starter
Local dealer has one. $1.65.
IBA Member
post #9 of 19 (permalink) Old 12-02-2015, 08:57 AM
Dos_Equis's Avatar
Dang it!
I am having the same issue. 2013 Cross Country with 16,000 miles.
How easy is to replace?
http://www.victoryforums.com/picture...pictureid=9378
http://www.victoryforums.com/picture...pictureid=9370
On the meantime I will try pushing it back in place.
2013 Cross Country (Sunset Red)
-- Rusty Jones Customs mod mufflers, Power Commander-V, Lloydz Hi-Flow Air Filter, Lloydz ATS @ 6+, Tarzanz Bagger barz.
Houston, TX
Dos_Equis is offline
post #10 of 19 (permalink) Old 12-02-2015, 09:21 AM
I like what you used to compare the oil spot size.
