Turn signal issue-2010 Kingpin - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 11-18-2012, 04:19 PM Thread Starter
Default Turn signal issue-2010 Kingpin
Today on a ride, I noticed my right front turn signal was flashing fast, rear right was doing nothing. Stopped at the auto parts store to pick up a pair of new ones. New bulb did the same thing. Swapped originals right to left, same thing. Where do I start looking for the problem?
2010 Kingpin
guitfit is offline
post #2 of 7 (permalink) Old 11-19-2012, 04:52 AM
gibson's Avatar
right rear socket is the problem make sure you are getting black wire to ground continuity, bu/r wire is the voltage from the ECM. It is protected by a diode. So any back feed will pop the diode. If you have not changed your lights to LED you should be OK. dielectric grease in the socket to keep corrosion out.
2012 Fireball Jackpot
gibson is offline
post #3 of 7 (permalink) Old 11-19-2012, 06:24 AM Thread Starter
Is the diode located in the socket? And if so, is it replaceable? Can I find one at Radio Shack? Value?
2010 Kingpin
guitfit is offline
post #4 of 7 (permalink) Old 11-19-2012, 08:24 AM
gibson's Avatar
did you check to see if you was getting voltage to the bulb? harness under the seat to the fender. If the front bulb has power the diode is ok so it has to be the wire harness connection or the socket.
gibson is offline
post #5 of 7 (permalink) Old 11-20-2012, 03:27 AM Thread Starter
I checked, no power to the left signal. I guess it's time to pull the fender and see what's going on under there. Thanks. BTW, have a great Thanksgiving!
2010 Kingpin
guitfit is offline
post #6 of 7 (permalink) Old 11-20-2012, 05:14 AM
gibson's Avatar
Attachment 8859here is a few from the book that shows the connectionAttachment 8860
gibson is offline
post #7 of 7 (permalink) Old 11-22-2012, 11:43 AM Thread Starter
Thanks for your help gibson. I'm glad I didn't need those schematics. When I took the fender off and looked at the wiring harness, I noticed both connectors for the left turn signal had come apart. I just plugged them back in, zip tied the rest of the wiring so it would stay behind the plastic shroud in the fender, and put it back together. It works! Have a happy Thanksgiving!
2010 Kingpin
guitfit is offline
