XC Lower air deflector install help? - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 11-21-2012, 10:25 AM Thread Starter
BThomas's Avatar
Default XC Lower air deflector install help?
I am getting ready to install a used set of factory lower air deflectors on my 2012 XC and have looked in my manual as well as done multiple searches for some directions but haven't found any.
I'm specifically trying to figure out if I'm to install the shields completely perpendicular to the forward direction of travel or if I should place them at an angle.
Also trying to figure out if the deflector bracket should bolt to the outside of the two fork brackets or if it should seat between them. My best guess is outside but wanted to be sure.
I'd really appreciate it if someone could either post or point me towards some online directions.
Thanks a bunch!
BThomas is offline
post #2 of 11 (permalink) Old 11-21-2012, 11:55 AM
dtmmil's Avatar
Sorry no instructions here, but are they the ones that bolt to the bottom of the fairing? or the forks? If they are the ones that bolt to the fairing, which crash bars do you have, forged or tube?
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 11 (permalink) Old 11-21-2012, 12:58 PM Thread Starter
BThomas's Avatar
Forks.... I have the forged bars-dont think the uppers would fit my bike due to the forged bars...
BThomas is offline
post #4 of 11 (permalink) Old 11-21-2012, 02:21 PM
dtmmil's Avatar
Gotcha, thats what I was getting at, I dont think they will, I have the same bars on mine. I have the victory soft lowers on mine and they helped a ton, I have thought about doing the fork mounted ones but not sure they will help where I need it now.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #5 of 11 (permalink) Old 11-21-2012, 02:57 PM Thread Starter
BThomas's Avatar
I have soft lowers too along with a Madstad windshield bracket (best $100 ive spent on this bike!). I am both pleased and completely satisfied with my new wind mgmt. Got the used deflectors cheap and figured i'd use them in place of the soft lowers during the summer months if nothing else. If i ever get them on, i'll let you know how they work with this combination....
Sent from my iPhone using Motorcycle.com Free App
2012 Cross Country--trunk at times, stereo/amp upgrade, Madstad Windshield bracket, old-man style heated seat/grips, RPW Exhaust/Lloydz ATS and filter, PCV/AT, Cycleops Cheese, side covers and primary insert, soft lowers, a bit of chrome...
BThomas is offline
post #6 of 11 (permalink) Old 11-21-2012, 03:17 PM
No directions but I do have this from the instructions that might help.
post #7 of 11 (permalink) Old 11-21-2012, 04:29 PM Thread Starter
BThomas's Avatar
Hey BBob, thanks so much for taking the time to post this but i probably wasnt clear in my above post. Im trying to install the clear plastic lower deflectors on my forks like the ones in this picture... Again thanks!ImageUploadedByMO Free1353536887.314579.jpg
BThomas is offline
post #8 of 11 (permalink) Old 11-21-2012, 04:55 PM
Oh! Got it now. I always put them at a little bit of angle to where the outer edge is a little further back than the inner edge.
One time I got the bright idea to turn them the other way when I crossed the desert in a 117 degree temps for added air flow to the oil cooler and heads. Well, it worked, but I got so much heat on my lower legs I was just about cooked when I got to my destination. I'm sure the bike was happier but I sure wasn't.
post #9 of 11 (permalink) Old 11-21-2012, 07:31 PM
Jeepster's Avatar
Thanks a bunch!
Sent you a PM. I have a PDF of the instructions but it is too big to post.
'11 XC
Stage 1
Jeepster is offline
post #10 of 11 (permalink) Old 11-21-2012, 10:50 PM Thread Starter
BThomas's Avatar
Thanks a lot! PM sent.
BThomas is offline
