fast idle is not working - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 11-21-2012, 07:21 PM Thread Starter
cjanicke's Avatar
Default fast idle is not working
The fast idle control is not working on the hammer premium. Is this a cable or a switch?. I know it should be covered by warranty, but I'm to far from dealer if it is an easy fix. Anybody got ideas to fix this? It won't start up very well in the cooler temps. 2007 hammer premium.
2007 Hammer S
2007 Hammer Premium
2009 KTM 450SX
cjanicke is offline
post #2 of 7 (permalink) Old 11-21-2012, 08:46 PM
Tarzan's Avatar
It is a cable. It should have 1/8 to 1/4" freeplay at the lever.
It is outlined in the service manual.
'14 Ness XC
Tarzan is offline
post #3 of 7 (permalink) Old 11-22-2012, 10:13 AM Thread Starter
cjanicke's Avatar
do you know where the cable adjuster is? Is it down at the fuel injection? I don't have a service manual.
Happy Thanksgiving to you and thanks.
2007 Hammer S
2007 Hammer Premium
2009 KTM 450SX
cjanicke is offline
post #4 of 7 (permalink) Old 11-22-2012, 10:43 AM
If you dont already do this, try having the handlebars turned all the way left when you use it. I believe that puts a little more tension on the cable and may help until you can find the adjustment for it.
2006 Hammer
The Wolf is offline
post #5 of 7 (permalink) Old 11-23-2012, 04:27 AM
Cable adjuster is on the thrttle body under the tank. Have you had the housing apart for any reason before it started this? I know getting the cable and the plastic lever all back in place is a major pain in the a$$ and if its not right then the lever will not pull the throttle body open like normal. I would make sure that is all right before i pulled the tank to adjust it under there. Also wouldnt hurt to clean your throttle body out if you pull the tank. My 06 jackpot seems to get alittle hard starting every 3000 miles or so and its always due to alittle bit of black carbon build up on the bores and alittle on the butter fly flaps. Once i clean the throttle body i dont ever need the high idle lever she just fires right up super easy. Just alittle something to look into.
2006 Extreme vegas Jackpot
S&S intake
05 hammer drag map
RPW Swept pipes
2013 red blacked out cross country
High, low HID kit
Ness grips
Ness Rad III mirrors
Noemtz Thunder Monster exhaust
Lloydz air filter
VM1 Cams done by Rylan @ The Vic Shop
lloydz timing wheel
Trvshonda is offline
post #6 of 7 (permalink) Old 11-23-2012, 11:11 AM
Do a search here for a service manual and down load it to your computer. There are plenty manuals here.
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton vote.
No Tapatalk.
Don't Text and Drive ​​
visionjohnny is online now
post #7 of 7 (permalink) Old 11-23-2012, 02:59 PM Thread Starter
cjanicke's Avatar
I haven't touched anything on the bike. I got it in September and it was still brand new so either something wasn't quite right from the beginning or something gummed up from sitting over the last 5 years. The lever hasn't worked since I have had it. Thanks for ideas. I will check the cable first. I will pack up and have it fixed under warranty if it is much more involved. I'm sure I could do it, but it might be a good time to take the wife shopping.
2007 Hammer S
2007 Hammer Premium
2009 KTM 450SX
cjanicke is offline
