re-mapping problems - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 11-23-2012, 06:02 PM Thread Starter
Default re-mapping problems
HI everyone, I have a 2012 highball and just installed the shotgun pipes and airbox and took it to the dealer for remapping and now the rev limiter goes off at 4100 rpm's. Dealer has no idea, suggested computer needs to "learn" and then adjust but doesn't sound right. Before remap rev limit was around 5600. Has anyone ever heard of this and any idea how to fix?
wildjim31 is offline
post #2 of 4 (permalink) Old 11-23-2012, 08:35 PM
Sounds like it didn't take. It happens sometimes and the only cure is to reflash it.
post #3 of 4 (permalink) Old 11-24-2012, 04:04 AM
half_crazy's Avatar
The ECU will not 'learn' anything. The download is corrupt.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #4 of 4 (permalink) Old 11-24-2012, 11:42 AM Thread Starter
Default remap
Thanks for the help, will take back to dealer.
