VFCIII or Power Commander 5 - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 11-30-2012, 03:23 AM Thread Starter
Default VFCIII or Power Commander 5
So I am going to buy the Concept customs ground pounders and I am thinking of either a lyods or SS intake. So when looking at prices for a Power Commander5 I found them to be $295. The VFCIII cost is just shy of that at $275.
Would the extra 20 bucks be well spent over the VFCIII?
Anyone seen a lower cost for the Power COmmander?
Also has anyone done any comparison testing between Lloydz and S&S?
Hotwired is offline
post #2 of 7 (permalink) Old 11-30-2012, 05:39 AM
GatorJoe's Avatar
Can't answer that but subscribed to see some input ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #3 of 7 (permalink) Old 11-30-2012, 06:33 AM
I think if I had it to do over again; I would go with the VFCIII instead of the PCV w/AT (Auto Tune) simply because I had some connection issues with the PCV and AT. When it works it works great and it does just fine most the time but it has caused enough issues for me that I would not buy one again. JMHO. Lots of other people have had no issues at all so maybe I'm not the best person to listen to on this issue.
The VFCIII can be set up without a dyno but to get the most out it; a dyno tune should be done when the bike is set up the way it will stay.
post #4 of 7 (permalink) Old 11-30-2012, 07:51 AM
Roadrocket's Avatar
What year bike?? 2008 & later get the PCV. Prior yrs get the PCIII
The Truth is Often Painful
2011XC
Roadrocket is offline
post #5 of 7 (permalink) Old 11-30-2012, 08:31 AM
the only thing is and might not be a problem with your application but power commander lets you add and take away fuel and most others only add fuel
hammer316 is offline
post #6 of 7 (permalink) Old 11-30-2012, 12:14 PM
jaysonL's Avatar
If you are just sticking with the air cleaner and pipes, then the VFC III will do fine. If you want to build a motor and squeeze every drop of performance out of the motor, get the PC V.
2009 Kingpin 8 Ball
Freedom Performance sharp curve radius pipes
Cross Roads bags mounted with Witchdoctor brackets
Kingpin tour tins
jaysonL is offline
post #7 of 7 (permalink) Old 11-30-2012, 12:26 PM
SilentUnicorn's Avatar
Considering this as well. My bike is so lean that if i take any fuel away it will starve.
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
