oil consumption???? - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 12-03-2012, 11:54 AM Thread Starter
oil consumption????
I have a 2008 Hammer, I cked the oil level today and for a first, it was a little low, it came to the bottom line of the 2 that you use. The bike has 18.000 miles on it. Is this normal to use a little oil?
gary mcclanahan is offline
post #2 of 14 (permalink) Old 12-03-2012, 12:04 PM
saddlebag's Avatar
If it's the first time you checked it, how do you know if it just wasn't filled too low to begin with?
My XR has 12k miles and I haven't noticed any oil use.
http://www.victoryforums.com/signaturepics/sigpic6903_1.gif
2011 Cross Roads
saddlebag is offline
post #3 of 14 (permalink) Old 12-03-2012, 12:22 PM Thread Starter
oil consumption???
I bought the bike new and I have changed the oil myself every time. Believe me I take a careful measurment of how much oil I put in the bike. The only oil change I didnt do was the first 500 miles. I always check it several times between changes. It was slightly low ths time?
post #4 of 14 (permalink) Old 12-03-2012, 12:26 PM
saddlebag's Avatar
Sounds like I've got 6k more miles left before I need to start adding oil.
2011 Cross Roads
post #5 of 14 (permalink) Old 12-03-2012, 03:27 PM
Did you check oil first thing before going for a ride or starting the motor or at some other point in the day? The reason I ask is because it can take up to 30 minutes for all the oil to drain back down into the sump where we get the readings from after the motor has been run.
post #6 of 14 (permalink) Old 12-03-2012, 03:38 PM
Tims_04V92TC's Avatar
Got a V92 that barely moves off the mark btwn oil changes at 4K, just for info, not oil debate, using Vic 20-40.. I have put 19K on it, has 39K total. I run the piss out of it!
3K on the Vision, hasn't move a bit since I changed the breakin oil out.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #7 of 14 (permalink) Old 12-03-2012, 04:30 PM Thread Starter
I cked it before the ride, the motor was cold.
post #8 of 14 (permalink) Old 12-03-2012, 06:32 PM
half_crazy's Avatar
I haven't looked in a while, but I know mine has well over 65K miles on it. It has never used a drop of oil.
If it's suddenly drinking oil, the only thing I can think of is a head gasket.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #9 of 14 (permalink) Old 12-03-2012, 08:02 PM
and we know how you baby your bike half_crazy
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #10 of 14 (permalink) Old 12-04-2012, 06:52 AM
half_crazy's Avatar
Yeah, I ride like a girl.
A couple of years ago it started smoking out one pipe and drank 1/2 a quart of oil in 12 miles... head gasket was blown. That was when the engine and trans got completely rebuilt since it had almost 50K miles on it and had to come out of the frame anyway. In reality the new engine only has close to 20K miles... but none of the three engine configurations ever used any oil (stock, 104" big bore, or 110" stroker). These motors are tight on the oil retention thing.
