LED Turn signal Equlzer? - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 12-03-2012, 01:03 PM Thread Starter
webberOU's Avatar
Default LED Turn signal Equlzer?
Quick question and probably a fast answer. I've looked and looked but couldn't seem to find a definitive answer. Do I "HAVE to HAVE" a load equalizer if I install Chromglow fork wrap LEDs. I know the blink rate is much faster but i figure it will be more noticable so why not just leave it. I'm not going to blow a fuse or shorten out anything am I? leaving the back ones stock for now. Thanks!!
webberOU is offline
post #2 of 4 (permalink) Old 12-03-2012, 01:09 PM
CrossRoads's Avatar
You won't burn anything, but you might get a ticket - quoting from my memory, the legal speed for turn-signals is 60-120 flashes per minute. Even if you do get a ticket, you won't get your license suspended.
CrossRoads is offline
post #3 of 4 (permalink) Old 12-03-2012, 01:25 PM Thread Starter
webberOU's Avatar
Didn't know that, thanks! Will one equalizer work both back and front? i've read mixed answers.
webberOU is offline
post #4 of 4 (permalink) Old 12-05-2012, 06:55 PM
Mrwadman's Avatar
http://www.chromeglow.com/catalog.asp?prodid=650635
One is all you need. Put this on my High Ball. Zenolen Infernal LEDs front and back. Normal flash speed all around. You will not get a fast flash if you loose a turn signal with this set up like you would with Halogens and one burned out.
Mrwadman is offline
