Llyodz bore and stroke kits - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 12-10-2012, 09:35 AM Thread Starter
Send a message via AIM to JackPt
Default Llyodz bore and stroke kits
Potentially looking to spend some of my tax returns in early 2013. I've done some research and I know the cost of the kits up front. My question is to anyone who has done both to their 100ci motor, what was the labor cost and amount of hours required to do it (So total for parts and labor)? Were there any other modifications outside the kits that you also needed to add/wanted to add?
2014 Cross Country (Two-Tone Suede Supersteel & Black) Chrome D&D exhaust, Power Commander V, Lloydz air intake, Klockwerks tinted flare windshield.
*sold*2008 Jackpot (color midnight cherry with a ton of mods)
JackPt is offline
post #2 of 9 (permalink) Old 12-10-2012, 10:10 AM
half_crazy's Avatar
Big bore is cheaper... don't have to split the cases. With a stroker you'll be replacing the crank, rods... lots more labor too.
You will need a better airbox, a fuel controller, some cams... and the pipes you have will be holding you back from getting the power you would normally get.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #3 of 9 (permalink) Old 12-10-2012, 10:17 AM Thread Starter
How much was the big bore after labor? Also I like the look of the ness pipes a ton. I assume I would have to switch to like an RPW or similar to keep that look with the new motor mods.
JackPt is offline
post #4 of 9 (permalink) Old 12-10-2012, 12:25 PM
half_crazy's Avatar
It's been a few years... you should ask whoever is going to build it.
post #5 of 9 (permalink) Old 12-10-2012, 12:30 PM Thread Starter
I'm looking for ball park. I'm going to talk to Kyle at KMC Motorsports as his shop is about 45 minutes from my home.
JackPt is offline
post #6 of 9 (permalink) Old 12-16-2012, 08:05 PM
woodrow731's Avatar
I did the work myself and the bike is easy to work on. if you have some knowledge and common sense it will be cake. i took it to get tuned and made 115 hp and 127 tq with a stage one victory pipe and it would make more with a better pipe. i got on ebay and ordered a copy of the manual for my bike because you can mess up the timing if you do not know how to set it. the worst part of the whole build was getting the engine out and in. it definitely takes patience. I would do the s&s 495. it will cost a little more money but it is worth it.
if you send your stuff to lloydz be prepared for it to take awhile.
here are the places i got my parts.
cams,carriers and valve springs: http://www.arizonavictory.com/eshopp...tSetLiftUp.htm
you will have to by the nuts and bolts for this from victory or anyone who sells them for the early style carrier.
109 big bore:http://www.lloydz.com/store/item_vie...itemid=1000088
variable clutch:http://www.lloydz.com/store/item_vie...itemid=1000079
if you have any questions do not hesitate to ask.
2010 vegas 8-ball
1 1/2 lowering kit
torque tubes,pc-v
vic performance pipe
109 big bore
s&s .495 cams
variable clutch
woodrow731 is offline
post #7 of 9 (permalink) Old 12-16-2012, 10:35 PM
This confirms what others have been saying about not using the S&S cams unless it is on one of the steel frame bikes and then; it would be best if the piston's were changed out for more compression so the 495 cam's can work the best for what they were designed to work with.
The bagger and touring class Vic's have a lower compression unless the piston's are changed out so more compression is added. The 495's need that added compression to do their magic from most of what I have read. Does anyone have more info to add to this concept? HC?
Of course, turning a bagger or touring bike into a hot rod might shorten engine life but for those looking for that much more hp/tq; it's usually not that much of an issue. Just rebuild when it wears something out, eh. Good stuff and fun!
Thanks much! This is really helpful!
post #8 of 9 (permalink) Old 12-17-2012, 04:46 AM
half_crazy's Avatar
Again, these are questions best asked of Kyle and Lloyd.
This would be true... IF you had to use radical components to make power. With the Victory engine, you don't.You can make impressive power and have a very mild and reliable engine.
post #9 of 9 (permalink) Old 01-06-2013, 10:18 AM
woodrow731's Avatar
It is important to be sure that the engine's compression ratio matches the recommended ratio for the cam you are selecting. Too little compression ratio (or too much duration) will cause the cylinder pressure to drop. This will lower the power output of the engine.
With too much compression ratio (or too little duration) the cylinder pressure will be too high, causing pre-ignition and detonation. This condition could severely damage engine components.
Does that help at all?
2010 vegas 8-ball
1 1/2 lowering kit
torque tubes,pc-v
109 big bore
s&s .495 cams
variable clutch
