rear tire change/pulley bollts - Page 2 - Victory Forums - Victory Motorcycle Forum
post #11 of 21 (permalink) Old 12-20-2012, 08:49 AM
Wow, I have NEVER had to remove a pulley for a tire change!
I've removed and transplanted pulleys when swapping out wheels though, and ended up re-using the bolts. Same for the disc rotors. But, the book does say to replace them. Your call.
And... 10k and showing cords seems like awfully low mileage. I've been averaging 16-17 thousand miles on my rear E3's and still had some tread left. The trick is to keep the minimum cold tire pressure at 41psi !!!
2011 Silver/black Vision, Ness Big Honkers, Ness Twin Sucker, PC-V w/AT, Lloydz VM1-DR cams, Lloydz Adj Intake, Lloydz Variable Timing Wheel.
2006 110" (133hp/142tq) +nitrous Kingpin (sold)
Gunslinger is offline
post #12 of 21 (permalink) Old 12-20-2012, 09:23 AM
half_crazy's Avatar
I use a manual tire machine. It requires the pulley come off. I have always just re-locktited and reinstalled with existing hardware. They look just fine after 7 tire changes... If I'm not breaking them, I doubt you will.
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #13 of 21 (permalink) Old 12-20-2012, 09:24 AM
jbasile's Avatar
Yea its a pain.......A limitation of the tire changer I use. It can be done with the pulley intact but its quite a bit easier with it removed. Especially with the 180 on the rear of the Pin which is a bit of a battle to put on.
jb
jbasile is offline
post #14 of 21 (permalink) Old 12-20-2012, 09:41 AM
half_crazy's Avatar
Originally Posted by jbasile View Post
It is HIGHLY unlikely you could even get them anyway as is the case with Victory parts. So re-use them.
They sell bikes, but they dont supply parts for them. Pathetic company.
Funny, my dealer has had almost everything I ever needed in stock. When I order parts they arrive in just a few days. I just bought all the grommets for both side covers and the right cheese wedge, all the metal clips for both cheese wedges, and all the rubber parts involved in swapping the fuel pump to a new gas tank... everything was in stock at the dealer. Voltage regulator was in stock, but I ordered the stator and had it in 3 days.
post #15 of 21 (permalink) Old 12-20-2012, 10:49 AM
SilentUnicorn's Avatar
This place has them http://www.2wheelpros.com/oem-parts/...8878-part.html
and here
and there is of course macmaster carr
pn 98093A761 cost is 6.71 for 10 screws.
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
post #16 of 21 (permalink) Old 12-20-2012, 01:47 PM
Most if not all tire machines do not really handles the Vic pulleys. There is a dollar bill Clarence. You have to look at the edge of the pulley you'll see it did make contact with the machine jaws.
I would think re using the bolts would be ok. Clean them good and use red lock tight.
Think of it this way if dealer had bolts in stock then they put in new bolts if they do not have bolts in stock then they don't use new ones.
H-D bolts would walk out cause no lock tight was used or it was a aftermarket rim.
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton vote.
No Tapatalk.
Don't Text and Drive ​​
visionjohnny is online now
post #17 of 21 (permalink) Old 12-20-2012, 02:12 PM
CrossRoads's Avatar
Most if not all tire machines do not really handles the Vic pulleys...
I don't know about most (cannot comment due to lack of knowledge), but for sure not all, as my dealer did it in front of me (replaced rear tire) with the pulley attached the whole time.
CrossRoads is offline
post #18 of 21 (permalink) Old 12-21-2012, 01:12 AM
I would pull the rotor and reuse the bolts on it long before I would reuse the bolts on the pulley. Once the bolts are stretched when torqued; that's it. They are no longer as strong as they once were. For those who are reusing them over and over; cool man but I think that is more luck than anything else.
Did they say why they couldn't just turn the wheel over and pull the rotor instead of the pulley?
post #19 of 21 (permalink) Old 12-21-2012, 04:31 AM
gibson's Avatar
I do not know what the big deal is.. If it was bolts on a car head, I would say yes get new bolts. You do not get new lug nuts when you change your tire on your truck or car. And the stretching a pecker goes through, you do not get a new pecker. Or wish we could..
2012 Fireball Jackpot
gibson is offline
post #20 of 21 (permalink) Old 12-23-2012, 07:19 PM Thread Starter
sgtfixit's Avatar
Default bolts ordered
Bolts ordered thru Kate...$20 w/s&h. Will not reuse the old pulley ones. locktited them as recommended. Now if the rain will let up so I can break in the new tires.
MSgt Ret. Security Forces USAF/Lompoc, CA
2011 Victory Cross Country (Imp Blue)
-Mods-Vic Military Salute Wedge Covers/Madstad with stock shield/Floor Board Hwy Pegs/2012 Hard Lowers/Hard Bag Bars/adj. pass. foot rests/+2 SRVT Pull Back Bars/Mirror extenders/LED driving lights/WOLO horn/RicZ laid down plate bracket/Kuryakyn Brake Pedal/Signal Dynamics headlight modulator/Custom Dynamics Brake light Strobe/LED rear plate/1/4 turn throttle ring/Lloydz timing wheel +4
sgtfixit is offline
