Oil and Filter info
I been collecting info on filters and oil. FWIW - I'm running with the WIX with Vic oil....till the next oil change anyway.
Oil Filter
20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket, 3.5" long. These all use synthetic media and accordion wrap.
• * Purolator ML 16851,
• WIX 51356 or 51356XP , $7.99/O’Reilly’s
• Mobil 1 M1-110, $12.__/Advance
• Bosch 3323, $13.__/Advance
• NAPA PFL 41365
• Super-Tech ST7317, $2
• Polaris 3084963 - $8.54
• K & N – 198 - $13.99
Motor Oil - 20W - 40
• Rotella T6 5W-40, synthetic, $23.99/Advance
• Lucas Synthetic SAE 20W-50 - $
• Mobil 1 V-Twin 20W-50 synthetic, $9.49
• Mobil 1 Racing 4T 10W-40 was previously known as Mobil 1 MX4T 10W-40 - $11.99
• Mobil1 5W40 Turbo Diesel Oil? Not enough information
• Amsoil 20W-50 synthetic, $10.90
• Castrol V-Twin Power RS Semi-Synthetic 20W-50 - (#8178) - $8.99
• Castrol ACT-EVO X-TRA 4T Semi-Synthetic (#558754) – 1 gal $23.99
• Rotella T5 semi-synthetic (silver jug-4qts) - $16
• Victory Semi-Synthetic 20W-40
Oil Drain Plug: M12 x 1.5mm
Oil Drain Plug Washers: 12mm ID x 19mm OD x 1.3mm thick - copper crush washers
p.s Same washer that is used on Toyota R22
NAPA - bag of 25 Price $6.00
http://www.conquestcustoms.com-Drain Plug Crush Washer REFILL KIT - Dozen - Price $6.00
http://buywitchdoctors.com-5 Pack Oil Drain Plug Washers - Item # DP-WASH - Price $ 4.25
Air Filter
POLARIS VICTORY - Part # 7080858 - $59.99
K&N - Part # PL-1500 - $52.95
*Stay away from the Purolator Pure One oil filter. It is a very good filter but it may be too restrictive for the Victory engine for oil flow. Vic runs at Higher Oil pressure than the puro was designed for.
From 2016 Gunner manual:
"Engine Oil Specifications
Polaris recommends the use of only VICTORY Semi-Synthetic 20W-40 oil, Synthetic 15W-
60 oil or an equivalent oil designed for use with wet clutches (such as those with a JASO MA
rating). "
The keywords above being "recommends" not require, and "or equivalent oil designed for use with wet clutches such as those with a JASO MA rating."
the 15w-60 is the oil now made for the Indian.
JASO MA is not for motorcycles with catalytic converters, JASO MA2 is.
Replacement oil filters for MOBIL M1-110:
• AC-Delco PF1127
• AC-Delco PF2112
• AMSOIL EAO13
• AMSOIL EAO14
• AUTOEDGE AL7317
• Autolite for Oil Filters AL6607
• AUTOPAR FE309
• Baldwin B1402
• Baldwin B1431
• Baldwin B530
• Beck/Arnley 041-8075
• Beck/Arnley 041-8135
• BIG A 92356
• Bosch 3323
• Bosch 72179
• Bosch 72180
• Canadian Tire 17-1740
• Canadian Tire 17-1745-4
• Canadian Tire 17-1747-0
• CARCARE FL822
• CARCARE OF7317
• CARQUEST 85356
• CARQUEST 85357
• CARQUEST B4620
• CASTROL CAS7317
• CATERPILLAR 199-2239
• CENEX CO2867
• CENEX CO2868
• Champ LF486
• Champ PH2867
• CHRYSLER MD135737
• CHRYSLER MD137537
• CHRYSLER MD360935
• CROSLAND 2142
• CROSLAND 2163
• DEFENSE DL5343
• DEFENSE DL7317
• DELPHI FX1012
• DENSO 150-1009
• DENSO 150-1010
• DEUTSCH D376
• Donaldson P502007
• Donaldson P502063
• EVERGARD E2868
• EVERGARD E4620
• FIRESTONE TF-4620
• FLAG C-3562
• FLAG C-4620
• FLAG C-6811
• Fleetguard LF3537
• Fleetguard LF3691
• Flying F PH6607AZ
• Ford F12Z-6731-B
• Ford F23Z-6731-B
• Ford F32Z-6731-A
• Ford XF5Z-6731-AA
• Fram PH5343
• Fram PH7317
• GENERAC 0A45310244
• GENERAC A45310244
• Grease Monkey GM14620
• Grease Monkey GM4620
• Group 7 V4620BP
• HASTINGS LF113
• HASTINGS LF240
• HASTINGS LF486
• HAVOLINE TFC-529
• HIFLO HF148
• Honda 15400-PLC-003
• Honda 15400-PLC-004
• Honda 15400-PLM-A01
• Honda 15400-PLM-A02
• HYSTER 324692
• HYSTER 3249692
• Hyundai 26300-35056
• IAPCO OF12
• IAPCO OF6
• JIFFY LUBE HL5343
• JIFFY LUBE HL7317
• K & N KN-148
• KENDALL K43
• KIA 0FE3R-14-302
• KIA 26300-3E010
• KRALINATOR L265
• KRALINATOR L365
• LEE LF-2867
• LEE LF-2867HP
• LEE LF-2868
• LUBER-FINER PH2867
• Magneti Marelli 1AMFL00003
• Magneti Marelli 1AMFL00025
• Mann Filter ML 1008
• Mann Filter W610/82
• Mazda F2Y0-14-302
• Mazda F2Y0-14-302A
• Mazda FEY0-14-302
• Mazda G6Y0-14-302
• Mazda G6Y0-14-302A
• Mazda JEY0-14-302
• Mazda JEY0-14-302A
• MERCRUISER 35-822626K04
• MERCRUISER 35-822626Q4
• MERCRUISER 35-877767K01
• MERCRUISER Q04
• MERCURY 1B227000
• MERCURY 35-877767Q01
• MERCURY G231123
• MERCURY G231123-T178499
• MERCURY G760300-1B226999
• MERCURY G760300-T408999
• MERCURY G960500
• MERCURY T178500
• MERCURY T178500-1B226999
• MERCURY T409000
• MICROGARD MGL7317
• MIGHTY M4460
• MILEGUARD MO5343
• MILEGUARD MO7317
• Mitsubishi 26300-35054
• Mitsubishi 2630035054
• Mitsubishi 30A40-00100
• Mitsubishi 30A40-00101
• Mitsubishi 30A40-00103
• Mitsubishi AW343979
• Mitsubishi MD135737
• Mitsubishi MD136790
• Mitsubishi MD321589
• Mitsubishi MD325714
• Mitsubishi MD332687
• Mitsubishi MD352627
• Mitsubishi MD360935
• Mitsubishi MZ690072
• MOBIL M1-110
• MOBIL MO4610
• MOBIL MO4620
• Motor Trend ML7317
• MOTORCRAFT FL 2007
• MOTORCRAFT FL 821
• MOTORCRAFT FL 822
• NAPA 1356
• NAPA 1357
• Nissan 15208-31U00
• Nissan 15208-31U01
• Nissan 15208-31U0A
• Nissan 15208-9E000
• Nissan 15208-9E01A
• Nissan 15208-PLM-A02
• Nissan 16510-82211
• ORIGINAL EQUIPMENT PLUS OF-450
• ORIGINAL EQUIPMENT PLUS OF-452
• Parts Master 61356
• Parts Plus PH2867
• PENNZOIL PZ-108
• PENNZOIL PZ-109
• PERFORMAX PO-108
• PERFORMAX PO-109
• PHILLIPS 66 PO1338
• PHILLIPS 66 PO1356
• PHILLIPS 66 PO1357
• PHILLIPS 66 WO1356
• PHILLIPS 66 WO1357
• POWER FLO SL14459
• POWER FLO SL14620
• PRO-TEC 164
• PRO/GAUGE PGO-4620
• PRO/GAUGE PGO-5343
• PROMOTIVE SL14612
• Purolator L14610
• Purolator L14620
• Quaker State QS14610
• Quaker State QS7317
• ROCKHILL 61356
• SECURITY SO-2867
• SECURITY SO-5343
• SERVICE 1 OF4460
• SERVICE PRO M4620
• SHELL SH48
• SHELL SH529
• SIERRA 18-7914
• SIERRA 18-7921
• SILVERLINE 21356
• STP S6607
• Subaru 15208-AA15A
• Subaru 15208-AA160
• SUNOCO O-37
• SUPERTECH ST7317
• TOKYO ROKI CO., LTD. LFS708-A
• TRUST PH2867
• TRUST PH2868
• UNOCAL PF1356
• UNOCAL PF1357
• VALVOLINE VO50
• WARNER PH2867
• WARNER PH2868
• Wix 51356
• Wix 51357
• Wix 51358
• Wix 57356
• YAMAHA 5JW-13440-00
• YAMAHA 5JW-13440-00-00
Ride safe:|
