Do I Need Heavier Clutch? - Victory Forums - Victory Motorcycle Forum
 44Likes
post #1 of 72 (permalink) Old 04-01-2017, 07:41 PM Thread Starter
Tourider's Avatar
Default Do I Need Heavier Clutch?
Hey guys,
Looking for confirmation of my suspicions and clutch advice.
Subject bike in my signature has 3,500 miles on it. About 6 weeks ago I noticed that gears 5 & 6 started to slip when I would give it some throttle at highway speeds. Now it has started to slip in all the gears. This only happens when I've been riding awhile and everything is good and heated up, which confuses me. I haven't opened the clutch cover but I'm pretty sure the plates are toasted.
Some considerations before you answer:
1. I installed the hydraulic clutch lever kit on it as soon as I brought the bike home from the dealer but have never felt as if the hydraulic clutch completely disengages when I release the lever. I have to let the lever almost all the way out to feel any friction.
2. Hydraulic clutch cannot be adjusted.
3. 500 mile checkup & oil change performed by reputable dealer & I also changed the oil again at 3,000 miles due to this problem. Victory oil both times.
4. I ride 2-up about 75% of the time and have pulled a 300-350 pound trailer about 1,700 miles.
5. No racing or hard riding on this bike.
Pretty sure the lack of clutch disengagement along with pulling a trailer 2-up are the roots of the problem. Do you agree?
Also, what would be the best clutch replacement setup? I have looked at the Barnett options of plates only, full scorpion clutch, or heavy duty diaphragm and pressure plate. Any other suggestions?
Thanks,
Stew
2016 Cross Country Tour
Mods:
Victory Passenger Arm Rests
Victory Back Rest
Heel Shifter
Hydraulic Clutch Actuator
Barnett Scorpion Clutch
2" Pull Back Handlebars
Bushtec Hitch
2013 Bushtec Quantum Trailer
Tourider is offline
post #2 of 72 (permalink) Old 04-01-2017, 08:02 PM
Motorbikerx's Avatar
Originally Posted by Tourider View Post
Hey guys,
Thanks,
Stew
I agree,
yeah you've gotta have freeplay for sure...why did you go hydraulic in the first place.
Lets see what the others reckon....
Victory Vegas 2010
100 cube / 6 speed
Lloydz 109"cube big bore
Lloydz. 495 cams kit
Lloydz Torque Tube Intake
Freedom Performance Slash pipes debaffled
Lloydz timing wheel @4 deg. and IAV
Barnett clutch spring
Barnett +6"cable
Lloydz Primary plate.
'Powerhouse' Dyno-tuned.
Progressive 465 rear shock
RaceTech Gold Valves and Progressive fork springs.
18" XC front wheel
1 3/4" (45mm) 'Burleigh Bars'
Stebel air horn.
12.342@106.32mph
Gold Coast,
Australia.
Motorbikerx is online now
post #3 of 72 (permalink) Old 04-01-2017, 08:16 PM Thread Starter
Tourider's Avatar
I went with hydraulic for less likelihood of being stranded with the wife on the roadside. Also a bit of OCD at play here since it irks me that one mirror is lower than the other with the stock cable. �� If it's going to keep burning clutches every 3,000 miles I will be going back to the cable.
They should have made the hydraulic adjustable, at least for the initial installation.
Mods:
Victory Back Rest
Heel Shifter
Bushtec Hitch
Tourider is offline
post #4 of 72 (permalink) Old 04-01-2017, 10:20 PM
Default It is adjustable
Check in the manual for the Vision on clutch adjustment. It is inside the side cover or clutch cover. The arm that actually goes into the side(primary cover) has to have a bit of free play. One guy I know set his Vision this way.
Goodyear, Arizona(USA) 2011 Victory Cross Roads, Black police bag guards, black engine guards, black Vegas 8 Ball handle bars, Triumph Tiger mirrors, Triumph hand grips, set speedo/tach back 5" , adjustable timing wheel, Lloyzz Fuel Programmer III & air filter. Modified exhaust, made stock into 2 into 1. Moved front fender forward. MRA windshield.
Speedblue is offline
post #5 of 72 (permalink) Old 04-01-2017, 11:45 PM Thread Starter
Tourider's Avatar
Thanks for The reminder. I read about that somewhere as well last fall but decided to leave it alone since the bike was brand new. Since I'm likely going to at least replace the frictions and steels, I'll try it now that I have to remove & reinstall the arm anyway
Stew
Mods:
Victory Back Rest
Heel Shifter
Bushtec Hitch
Tourider is offline
post #6 of 72 (permalink) Old 04-02-2017, 06:25 AM
What is going on with all the clutch posts? they are dropping like flies....
@Tourider There is no way your clutch should be spent with 3k miles on the bike. I suspect that your feeling that it "wasn't right" after the initial hydraulic install was correct. You've probably been riding around half engaged since you did the change over.
I'd suggest you have the current clutch replaced asap, then ditch the hydraulic system for a Barnett stainless steel cable(which has better feel than the stock cable or hydraulic system and is adjustable), then get a Sav-UR-Ride cable to throw in your bag so there's no worries about being stranded due to a broken cable..
Barnett SS cable
Sav-UR-Ride
kevinx, RICZ, ftwflh and 3 others like this.
The Destroyer Approaches
Vic Tri-Oval Mufflers, Lloydz AF, ATS+2, PC-V tune by Dyno Solutions
Drag Specialties low-profile Touring Seat, Klock Werks Klip Hanger bars
Kuryakyn ISO grips/bar ends and SwingWing rear boards
post #7 of 72 (permalink) Old 04-02-2017, 07:51 AM
philmonger's Avatar
Agreeing with PaiN here regarding the Barnett cable and the Save-ur-Ride. Barnett cable feels much better than stock and Save-ur-Ride is cheap reliable insurance
kevinx, RICZ and ftwflh like this.
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #8 of 72 (permalink) Old 04-02-2017, 02:49 PM
There is nothing wrong with hydraulic clutches. You get them set up right they'll last a long time. When its properly installed it self adjust on every pull.
Look up at BBobs signature. You'll find shop manuals there. Find the one for vision and read about the clutch.
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton
No Polaris ever again
Don't Text and Drive
post #9 of 72 (permalink) Old 04-02-2017, 07:06 PM
half_crazy's Avatar
If a guy needs to refer to the manual to figure out how to adjust a clutch for freeplay, he should probably put down the tools and step away from the motorcycle.
Just sayin'
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes airbox, RPW Thor pipe, Lloydz ECU, PC-III, PTS (-2), Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
half_crazy is offline
post #10 of 72 (permalink) Old 04-02-2017, 08:54 PM Thread Starter
Tourider's Avatar
I tried adjusting the clutch pinion shaft arm according to the Vision manual today with no luck. In the original setup, the slave cylinder rod is extended to its maximum limit and Keeps the the pinion arm pulled about 1/16" measured where the cylinder rod attaches. Rotating the arm one notch toward the slave makes it well outside of the 15 +/- 5 degree range and causes too much free play.
Not sure if this means anything but I noticed in the photo on page 9.10 that the end of the release rack with the screwdriver slot is flush with the outer surface of the primary cover. Mine is a 1/4" or more inward.
Any other suggestions, or am I just SOL?
Thanks,
Stew
Mods:
Victory Back Rest
Heel Shifter
Bushtec Hitch
Tourider is offline
