Springer front end - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 03-28-2010, 02:30 PM Thread Starter
Default Springer front end
I'm thinking about putting a springer front end on my bike(03 cruiser). I was wondering it simply bolts on and replaces the front forks or if there's more involved, like if I have to change the calipers and rotors or anything else. It anyone has done it, I'd really appreciate some advice and opinions on if it changed the handling of the bike at all. Thanks.
03 V92C Classic Cruiser
guitarman is offline
post #2 of 8 (permalink) Old 03-29-2010, 12:23 AM
The Diamond
diamondrmp's Avatar
I have not seen anyone that makes a springer front end for an 03 or any of the older style bikes. If you are thinking of using an HD brand or aftermarket for HD it won't work.
diamondrmp is offline
post #3 of 8 (permalink) Old 03-29-2010, 06:39 PM Thread Starter
Well I thought that might be the case but I was wondering if I had to modify it, how hard would it be? I really like the look of those and I don't mind spending the time working on it to get it to fit.
post #4 of 8 (permalink) Old 03-29-2010, 06:55 PM
The Diamond
diamondrmp's Avatar
Aside from getting a springer front end made. Cutting off the stock neck and replacing it with a HD neck would be next.
post #5 of 8 (permalink) Old 03-29-2010, 09:51 PM
kevinx's Avatar
WHOA there big guy.....Put the sawzall down!!!!!
The early HD front ends[pre 84] are VERY close to the stock C forks. About all you really need is a set of bearings with the HD inner dimension, and a Vic outer. Along with a spacer for the top tree. Then you would need to use some aftermarket HD brakes
kevinx is offline
post #6 of 8 (permalink) Old 03-31-2010, 05:10 PM Thread Starter
Thanks for the reply Kevinx. It's great having a direct line to a victory tech. Anyway, that doesn't sound too hard and I don't mind spending the down time getting it to work. I'm really trying to get a specific look for my bike and the springer would definately help.
post #7 of 8 (permalink) Old 04-04-2010, 03:43 PM
Let us know how it turns out and what ya had to do to get there.
VegasRider is offline
post #8 of 8 (permalink) Old 04-05-2010, 05:30 PM Thread Starter
For sure. I'm in the middle of painting it right now, but the front end is next on my list.
