Vegas Fork Oil Change - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 03-30-2010, 10:10 PM Thread Starter
Default Vegas Fork Oil Change
Anyone have some advice on changing the fork oil? The recommended interval in 15K miles or 2 years. Is this something a person with reasonable mechanical skills should tackle? Is there an easier way than totally disassembling the fork tubes? Thanks much.
SidB is offline
post #2 of 6 (permalink) Old 03-31-2010, 05:09 AM
Bungln's Avatar
did mine a couple times now. no easy way, gotta take the forks off and dump the oil out. my advice is that unless you are really hitting hard on bumps let it go. i didn't notice enough of a difference after i did it to make the pain worth it. just my opinion......oh and if you do decide to do it, don't forget to put the washers on top of the springs back in, don't ask how i know.
if the house is a rockin', don't bother knockin'
2004 Vegas.
swept pipes
S&S airbox
OD pulley
lots of chrome goodies...
70K trouble free miles as of 4/1/11
cheers
Bungln is offline
post #3 of 6 (permalink) Old 03-31-2010, 09:12 AM
The Diamond
diamondrmp's Avatar
I just did mine and I have the KMPS kit on my bike.
You'd be surprised how easy it is. The hardest part is putting the fork caps back on and that isn't really hard.
diamondrmp is offline
post #4 of 6 (permalink) Old 03-31-2010, 06:49 PM Thread Starter
Okay guys. I think I have it. Just to be clear though, all I need to do is take the tubes off, remove the fork cap, spacer, washer and spring, dump the old oil, purge the remaining oil by pumping the slider, then refill to the proper level and reverse the process to re-assemble? This could be fun!
SidB is offline
post #5 of 6 (permalink) Old 03-31-2010, 10:51 PM
The Diamond
diamondrmp's Avatar
Sounds like you're good to go!!
post #6 of 6 (permalink) Old 04-01-2010, 07:39 AM Thread Starter
Thumbs up Thanks Much!
You all are great. Thanks for the help!
SidB is offline
