Starter relay cross reference - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 04-05-2010, 11:40 AM Thread Starter
Default Starter relay cross reference
Ok. maybe I'm an idiot but I can't find a Bosh cross reference for my Siemens starter relay.It's for a 2000 V92C. The numbers on the Siemens relay are...V23132-A2001-A200 or LO 9933. Not sure which to use. Any helpful info would be appreciated.
ridds74 is offline
post #2 of 3 (permalink) Old 04-10-2010, 06:13 AM
The Important Factor To Take Into Concideration When Crossmatching The Relay Is The Current Draw Of The Starter Motor. Yours Is Between 90 And 120 Amps Under Load.the Points Of The Relay Should Be Heavy Enough For The Purpose Of Engaging Without Burning.
Good Luck
jontraub is offline
post #3 of 3 (permalink) Old 04-11-2010, 11:14 AM Thread Starter
Thanks for the info.I wtook my old relay apart and cleaned the contact points where they had fused together and now it is working fine! so i just sealed it back up and put it on the bike. Only problem is I already ordered the oem replacement from dealer. So now I gotta see if they will refund my money.
ridds74 is offline
