99 V92c Charging Issues - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 09-03-2011, 07:58 PM Thread Starter
Unhappy 99 V92c Charging Issues
I have a 99 V92c, Stage 1 slip-ons and K&N, I have a chip in the mail to fix the fuel mapping. About 1 month ago, the battery died and I replaced it with a new on. The alt was reading as high as 14v with the old battery. It had a bad cell and I though that was allowing it to over charge. The new one (charged properly on a charger before install) has only gone to 12.2, which makes me think the system (rec/reg and stator) was working fine. Last weekend I rode about 150mi and it showed 10.8-11.5 throughout the day. Today, it wouldnt go above 11.0 and was normally at 10.4-10.8 under a full load. The last stop of the day (local riding, maybe 20mi) the bike wouldnt start. The reading was 10.5-10.8 and not enough juice to turn the motor over. The lights all work, but I got the solenoid *click, click click* and had to jump it to get it home. Once here, it again wouldnt start and was showing 10.8. I dont believe the battery is the issue now. I remove it and keep it on a battery tender when I wont be riding the bike for 7 or more days. Does this sound like a bad rectifer/regulator, stator, coil, or (god forbid) the ecu???
Thanks in advance for the responses!
99 V92c
and a 01 Sv650s
jkbcby is offline
post #2 of 5 (permalink) Old 09-03-2011, 09:03 PM
CrossRoads's Avatar
Default Technical Question
This is a technical question, so I have moved the thread to the Victory Tech and Performance Section.
CrossRoads is offline
post #3 of 5 (permalink) Old 09-03-2011, 09:09 PM
kevinx's Avatar
If I were to just guess. I would say it is a regulator. If you plan on keeping the bike. You should go to a 38 amp system upgrade
kevinx is offline
post #4 of 5 (permalink) Old 09-03-2011, 11:52 PM
The Diamond
diamondrmp's Avatar
Welcome to the Victory Forums.
A few helpful pointers,
  • Please take the time to read the “Sticky” threads in the “Victory Forums Rules and New Members Introductions” forum. This will help you out a LOT with the Victory Forums.
  • The Search feature is your friend! You will find the answers to a lot of your questions by using it.
  • If you are asking questions that are of a technical/mechanical/electrical/performance nature, please place them in the “Victory Tech and Performance” forum. This will speed up a response. Placing them in the model specific forum can delay a response.
Please add the year and model of your bike to your signature, so we know how to help when you ask a question!
diamondrmp is offline
post #5 of 5 (permalink) Old 09-05-2011, 12:46 PM
Do the charging system upgrade, it really makes a huge difference in performance and I now don't have to worry about being stranded. Cost with oil change was about480.00
ray2001 is offline
