Transmission Noise - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 09-11-2012, 06:13 PM Thread Starter
Sandring's Avatar
Default Transmission Noise
The bike I am talking about is a 99 V92C and has 300 miles on it, but the tranny makes alot of noise?
Is this common for them to be very noisy? I have a few other bikes " Ultra Classic, Sportster " and they dont make any noise compared to Victory.
Thanks for any help in advance
Chris
1999 Victory V92C
Sandring is offline
post #2 of 10 (permalink) Old 09-11-2012, 06:15 PM
CrossRoads's Avatar
Chris
When was the oil changed last? I saw the 300 mile part, but also noted that it's a '99 we're looking at. If all fluids were not flushed out and replaced, you might want to do that before you turn it on again. That being said, the '99s were rough machines compared to nowadays standards.
CrossRoads is offline
post #3 of 10 (permalink) Old 09-11-2012, 08:11 PM Thread Starter
Sandring's Avatar
Ok I will change the oil and filter, along with the tranny oil.
I dont have a manual so if anyone can fill me in on what oil and how much, filter, what tranny oil, and how much to add I will get on it tomorrow.
I dont have a Victory dealer by me so I would need to get my stuff from the local MC dealer.
Thanks
Chris
1999 Victory V92C
Sandring is offline
post #4 of 10 (permalink) Old 09-12-2012, 06:40 AM
Atbyrne's Avatar
Thanks
Chris
You defiantly want to change the oil, but what kind of noise are you getting?
1. Noise all the time?
2. While idling with in neutral and clutch out?
3. While idling with clutch pulled in?
4. Noise when shifting, grinding noise?
5. Noise When shifting, big bang?
Oil, the Victory oil is a 20/40 simi synthetic. You will get all kinds of different thoughts on this. It will be up to you, just make sure it is not car oil and make sure it does not have friction modifiers in it. Stick with good brand.
Filter, I use a NAPA GOLD 1358, which is the same as the WIX filter #51358, K&N KN-303. You can usually order the Victory oil change kit online too. There is a dealer that sells them here. I think it is Honda East, he is a Victory dealer too. The engine and transmission is the same, so only changing oil once. The next problem you will find is your drain plug using an Allen wrench to remove. there is one in your tool kit, but would recommend getting a socket version. Now bigger problem is that there is a crush washer that needs to be replaced. these will come with the oil change kit, may be able to match it up at an auto parts place, but not sure. i was lucky enough to find 5 of them on eBay.
I hope this helps.
Travis
2011 Cross Country
PCV with Vic filter
Witchdoctors Muscle Mufflers
Painted inner fairing
Magnum 21" Wheel and Fender
Custom mounted CVO Tour Pak
Vicbaggers Bars, speaker grills,
and bezels
Atbyrne is offline
post #5 of 10 (permalink) Old 09-12-2012, 12:43 PM
kevinx's Avatar
The trans makes more noise then any other bike you will ever ride. Thing I am red flagged on is the miles. Was this thing in a crate all of it's life?? The 99-00 speedo is known for going to zero if the battery is unhooked, and there are LOTS of unscrupulous people out there that sell them as super low miles bikes
kevinx is offline
post #6 of 10 (permalink) Old 01-07-2013, 09:24 PM
ddahlen's Avatar
My 99 makes a very loud clunk as I go from gear to gear. I have been told this is okay, but it sure is loud.
1999 V92C
Household Cylinder Index (C.I.) 26
ddahlen is offline
post #7 of 10 (permalink) Old 01-09-2013, 07:21 AM
Tims_04V92TC's Avatar
+1 may not be a quick 100% accurate way to spot check the 300 miles but you can inspect the throttle bodies for build up. 300 miles should be spotless. BBob has th 00 manual for download, here's the link. Service Manuals
Should get you moving in the right dire cation. Oil change intervals going to be important, you will get more noise and clumsy shifting as you get past 2500. Throw some more info up as Atbyrne noted when you get a cance. Congrats on the purchase and safe riddin
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #8 of 10 (permalink) Old 01-09-2013, 07:24 AM
Like a horse ready to come out of the gate!!! I've actually grown fond of it....
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #9 of 10 (permalink) Old 05-23-2013, 03:24 PM
George D's Avatar
Ok, this is making me feel a little better. In neutral, with clutch out, it rattles when warmed up. The exhaust is so loud I can't tell if it makes any noice going down the road but it seems to get quieter under load.
George D is offline
post #10 of 10 (permalink) Old 05-27-2013, 09:48 PM
wbb
My 02 Touring Crusier makes a loud clunk when I change gears and the trans makes a lot of noise until the clutch is pulled in and then it's quiet. I'm not a mechanic but I've been told this is normal for these bikes. I've gotten used to it over the years.
2002 Victory Deluxe Touring Crusier
2010 Harley Road King
wbb is offline
