OiL light flashing - Victory Forums - Victory Motorcycle Forum
 5Likes
post #1 of 20 (permalink) Old 04-19-2017, 05:16 AM Thread Starter
Huckster's Avatar
Default OiL light flashing
While out riding my Oil light started flashing. I stopped at nearest gas station and added a quart....took of riding again and it started flashing again.....( only at speeds above 60 )...Headed home...light quit flashing. Has anyone had this happen ? I do need to change oil in it. The oil doesn't look bad.
2006 victory tour deluxe, 1980 xs650 Yamaha (hard tailed), 1975xs650 (hard tailed), 1977 triumph Bonneville 750 (basket case)
Huckster is offline
post #2 of 20 (permalink) Old 04-19-2017, 08:02 AM
VicVisionBulldog's Avatar
Any idea why it was a quart low?
13 Vision Tour - PCV, Top Filter, Stage 1 Pipes, soon to add wheel, Metz 888s
VicVisionBulldog is online now
post #3 of 20 (permalink) Old 04-19-2017, 08:08 AM
BP6666VR's Avatar
And AFTER you added a quart..... The bike had a low oil flashing light again? Never heard that before.... So where is the oil mark on the dipstick Now
Andre using TaPaTaLk
Cross Country Tour 2014 [B]
BP6666VR is offline
post #4 of 20 (permalink) Old 04-19-2017, 12:54 PM
Luciferiad's Avatar
try changing the oil filter first. That's the cheapest thing to troubleshoot, and sometimes filters block and make the gauges go wonky.
It's also possible the sending unit is bad. Both of those possibilities are preferable to the oil pump being bad.
RICZ and LILMAGS500 like this.
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #5 of 20 (permalink) Old 04-20-2017, 04:46 AM Thread Starter
Huckster's Avatar
I do not know why I was a quart low...Just wondering where is the oil sending unit.... Last year I broke the drive belt, and the neutral light has not worked since then. Could the belt have hit some wires and cause this ?
Huckster is offline
post #6 of 20 (permalink) Old 04-20-2017, 12:50 PM
kevinx's Avatar
The sender is on the bottom back corner of the case on the left side. 99-01 are famous for the flickering light. Especially if it has recently been washed, or ridden in the rain.
kevinx is offline
post #7 of 20 (permalink) Old 04-20-2017, 01:43 PM
do you know you check the oil with the bike standing straight up. You screw the dipstick until it seats and the unscrew it.
if you lay on the ground on the left side and look at the oil filter just to the left on the back edge of motor is the oil sending unit. It has a black slide on connector. Some model came with a rubber boot over it.
It only takes one drop of water to short it out
No Monkey in my garage.
No Orange in my county.
No Hillary Clinton
No Polaris ever again
Don't Text and Drive
post #8 of 20 (permalink) Old 04-20-2017, 07:07 PM Thread Starter
Huckster's Avatar
My Bike is a 2006 V92 TC....... Yes It was standing straight up when I checked oil ... and I seated the dipstick to pull it back out....
I plan on changing oil this weekend
Huckster is offline
post #9 of 20 (permalink) Old 04-20-2017, 10:02 PM
Motorbikerx's Avatar
A quart is a lot to be down, how long since it'd last been changed how many miles since it was on the full mark?
If it's not leaking it must be burning...excessive smoke?
Oily spark plugs? Compression test may be in order...
How many miles on the bike?
Victory Vegas 2010
100 cube / 6 speed
Lloydz 109"cube big bore
Lloydz. 495 cams kit
Lloydz Torque Tube Intake
Freedom Performance Slash pipes debaffled
Lloydz timing wheel @4 deg. and IAV
Barnett clutch spring
Barnett +6"cable
Lloydz Primary plate.
'Powerhouse' Dyno-tuned.
Progressive 465 rear shock
RaceTech Gold Valves and Progressive fork springs.
18" XC front wheel
1 3/4" (45mm) 'Burleigh Bars'
Stebel air horn.
12.342@106.32mph
Gold Coast,
Australia.
Motorbikerx is online now
post #10 of 20 (permalink) Old 04-21-2017, 04:40 AM Thread Starter
Huckster's Avatar
Hate to say this but its been about 3 years since an oil change.......Maybe 3-4000 on oil change...No leaks...nothing on floor
Huckster is offline
